Author Topic: clear gloss coat over decals  (Read 3324 times)
sleeper123
« on: November 14, 2017, 07:06:19 pm »
Hi just wanted some advice, can someone suggest a clear gloss coat for on top of decals on a plastic kit.
david48
Re: clear gloss coat over decals
« Reply #1 on: November 14, 2017, 11:44:54 pm »
Humbrol do a decal fix check out there web site there are some videos on how to use there products .
David
oldiron
« Reply #2 on: November 15, 2017, 03:13:17 am »
Be sure to use a decal fix such as Solvaset before you put a clear sealer over the decals. This will set the decal down over ridges and rivets and securely fasten the decal to the surface. A variety of clear over coats can be used as long as they don't damage the plastic the decal is applied to, from varnish to testor's glosscoat, or dull coat.
Howard
« Reply #3 on: November 15, 2017, 11:18:35 am »
 First make sure the surface you're putting the decals on is a gloss finish or you will get what's called silvering , as others have said use a setting solution I use microscale's  micro sol and micro set then once dry use any varnish you like gloss, semi, or Matt.
                             Regards Howard.
« Reply #4 on: November 15, 2017, 08:59:31 pm »
post altered. :-))
sleeper123
« Reply #5 on: November 16, 2017, 09:36:43 am »
Hi thanks for the suggestions I will look into some
