Author Topic: Ideas needed unusual project  (Read 8614 times)
ukmike
Re: Ideas needed unusual project
« Reply #25 on: February 01, 2018, 11:59:51 pm »
Soft solder in place, then remove pipe. Hold together on the bench with fire cement then silver solder. Clean up and refit.
Thanks Brian.
Your suggestion is the best and simplest so far. Unfortunately the metal tube is too thick and long to be heated enough using a soldering iron. It would require a blow torch to get it hot enough even for soft soldering.
Mike.
« Reply #26 on: February 02, 2018, 12:09:46 am »
Just for clarification....... silver solder flux + silver solder take over a soft soldered joint  :o
bfgstew
  • Comfortably Numb
« Reply #27 on: February 02, 2018, 12:18:29 am »
Mike try these for larger dia brass tubing.
http://www.gliders.uk.com/mobile/Brass/products/60/7/0
« Reply #28 on: February 02, 2018, 12:48:01 am »
sorry <*<...................."silver solder flux + silver solder will not take over a soft soldered joint"  :o
bj
« Reply #29 on: February 02, 2018, 07:33:12 am »
Use JB Weld (the slow cure version). It is good for approximately 650℉
Captain fizz
« Reply #30 on: February 02, 2018, 01:13:26 pm »
Just give the fire cement a try.
ukmike
« Reply #31 on: February 02, 2018, 04:06:05 pm »
Hello all.
The flanges are shaped and taped in place, (just until the screws arrive from China).
Exhaust tail pipes are angled and water nipples fitted.
Being as the fit is nigh perfect I am going to use the fire cement method.
Here are some pictures.
Mike.
bj
« Reply #32 on: February 02, 2018, 04:32:52 pm »
See photo attached
ukmike
« Reply #33 on: February 02, 2018, 04:45:23 pm »
Thanks BJ, will give that a look.
Mike.
Tombsy
« Reply #34 on: February 02, 2018, 08:25:08 pm »
Absolutely JB weld would work great, I’ve seen people use it to patch nitro engine blocks.
Brian
bj
« Reply #35 on: February 02, 2018, 08:30:50 pm »
See photo attached
Don't know what happened to the picture but it looked OK on the home pooter
Captain fizz
« Reply #36 on: February 02, 2018, 08:35:44 pm »
I do like the look of those servo linkages.
RST
« Reply #37 on: February 03, 2018, 12:12:14 am »
How about using blobs of RTV to hold the stuff together from one side, leave to set then solder from the other.  If you're worried about parts sticking to other parts of the hull then cover them in patches of parcel tape before using the RTV.  Not much sticks to brown parcel tape and I use it all the time for moulding / protecting parts!  Fire clay etc would probably work the same way as RTV.
You gotta try things for yourself though.  That's what modelling is all about!
ukmike
« Reply #38 on: February 05, 2018, 09:24:16 pm »
All done now and the fire cement worked perfectly.
They need a thorough buffing ready for the chroming, unfortunately, I don't have the wherewithall to do this as no buffing wheel but should be able to find
find someone who has.
Here are a couple of not very good pictures.
Mike.
Captain fizz
« Reply #39 on: February 05, 2018, 10:12:55 pm »
The guys doing the chrome will probably want to do the buffing themselves.
