Author Topic: 540 Motor short shaft  (Read 2889 times)
klz
« on: September 02, 2018, 09:48:34 pm »
Hello all, a club member went to howes models a couple weeks ago I asked him to get me a 12v 540 motor he came back with this one https://howesmodels.co.uk/product/johnson-540-3-pole-motor-4-5-15-volts/ I never looked at the motor when he handed it over I went to use it last night and the shaft is only 5mm long and none of the couplings I have will fit it as the grub screw barley holds it on once load is on it I'm sure it will just spin off.  Does anyone know any that will fit it the shaft diameter is 3mm
Andyn
Re: 540 Motor short shaft
« Reply #1 on: September 03, 2018, 12:21:32 am »
I could certainly relocate the grub screw on a coupling for you - dependent on what coupling you have. My concern echos yours though, even if you can get a screw on there, there's no guarantee of getting a good fit on the shaft with it being that short
skierdive
« Reply #2 on: September 03, 2018, 07:43:24 pm »
Just an idea, you could use a steel roll pin like the one in this link
https://www.accu.co.uk/en/slotted-spring-pins/10056-HSP-3-24-A2?uk_google_shopping=1&c=3&mkwid=s_dc&pcrid=291519246123&kword=&match=&plid=&gclid=EAIaIQobChMI9brDsruf3QIVkeF3Ch0COw1_EAQYASABEgJcb_D_BwE
af
This
is just an example as you would have to find one that had the correct internal diameter so that it would be a nice tight fit. The other end could then be fitted on to a short 3mm OD extension piece or directly on to a 3mm OD prop shaft.T
Also of course, it might be a lot less palaver to get another motor with a longer shaft  :-)
Ian.
klz
« Reply #3 on: September 03, 2018, 09:11:58 pm »
Andyn thanks for the offer of relocating the grub screw I think I will take Ian's advice and just get another one I might find a use for this motor later on.
« Reply #4 on: September 03, 2018, 09:46:29 pm »
Not to be a damp squib but a roll pin won't work...serval reasons but hay ho  ;)
If you can't get you coupling either Andy or  will sort it  :-))
KitS
« Reply #5 on: September 03, 2018, 10:25:17 pm »
Why won't a roll pin work?
I've used one on a motor shaft before, albeit not in a model boating context, and it worked fine.
Kit
« Reply #6 on: September 03, 2018, 11:37:15 pm »
British Imperial Framed electric motors are quoted in HP [Horse Power]
That 540 motor with a shaft like that is not even a Donkies Anything  {-)
Return to Sender or throw it in the bin...................
« Reply #7 on: September 04, 2018, 08:30:00 pm »
It would be a very small diameter roll pin, and I don't think it would leave much shaft left, and would probally sheer  {:-{
Page created in 0.02 seconds with 18 queries.
