Author Topic: ModelsbyDesign Shannon  (Read 269839 times)
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon
« Reply #500 on: December 28, 2019, 09:25:02 am »
Thank you John I'm glad your are finding things useful and I wish you success with the hatches and hope you'll share it with us  :-)
Hi Mike and thank you, the figures are from Speedline and look superb when painted to a high standard. I've been advised to sub mine out to one of those war gamer shops for a couple of beers  {-)
The figures will be available again eventually but for now I cannot say anymore. I will update when that changes as I'm sure there will be many interested.
These are painted by Ole Bodker in Denmark
https://techno.smugmug.com/Shannon/RNLI-Crew-figures/n-VTqbhc/
ANDY
mikew
« Reply #501 on: December 28, 2019, 09:53:45 am »
Many Thanks for the info.  :-))
Taranis
  • Balne Moor MBC
« Reply #502 on: December 28, 2019, 11:31:15 pm »
No modelling today but I've just put radar on test before bed.
Component shop £2.50 voltage reducer
<iframe frameborder="0" scrolling="no" width="1080" height="1920" src="https://api.smugmug.com/services/embed/9104010390_WSK5PDb?width=1080&height=1920&albumId=202572554&albumKey=kSPzbx"></iframe>
ANDY
Taranis
  • Balne Moor MBC
« Reply #503 on: December 29, 2019, 10:11:42 am »
This is now adjusted to 29rpm which I believe is the upper end of the tolerance.
My motor is not fixed in place and all the parts are simply push fit so not a nightmare to change a motor if it ever becomes necessary. I will probably fix the regulator inside the T and use thicker wire from there downwards
https://www.modelboatmayhem.co.uk/forum/index.php?topic=61758.msg680553
ANDY
Taranis
  • Balne Moor MBC
« Reply #504 on: December 29, 2019, 12:17:39 pm »
Sorry but my post above (503) has been modified with the wrong link.
This is now adjusted to 29rpm which I believe is the upper end of the tolerance. My motor is not fixed in place and all the parts are simply push fit so not a nightmare to change a motor if it ever becomes necessary. I will probably fix the regulator inside the T and use thicker wire from there downwards
ANDY
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon STEM HEAD
« Reply #505 on: December 29, 2019, 12:21:15 pm »
Brass angle used to make this as one symmetrical part before dividing. 1mm screws
ANDY
Taranis
  • Balne Moor MBC
Re: ModelsbyDesign Shannon Stem Head part II
« Reply #506 on: December 29, 2019, 04:36:41 pm »
Nearly complete. Worth noting that the release lever handle is different on early models and bends the other way on 13-15
ANDY
Taranis
  • Balne Moor MBC
« Reply #507 on: December 29, 2019, 06:58:05 pm »
Tomorrow Leeds Model shop re opens for a desperate gasp of air before shutting again. So I’ll be there early for my parts to finish the radar  :-))
The weather forecast is excellent so we will proceed from there to Filey for a quiet sea front walk and coffees  :-)  maybe to Scarborough from there
ANDY
me3
« Reply #508 on: December 29, 2019, 09:38:10 pm »
Looking good as ever! Radar looks amazing! They spin at different speeds depending on what range you are on!
Taranis
  • Balne Moor MBC
« Reply #509 on: December 29, 2019, 09:43:04 pm »
Thank you  :-)  I heard 26/29rpm so any of them I guess  :-))
John Huntley sent me a batch of Stem Head and Bow Roller pictures from Scarborough today that show a few differences to the pictures I was working from. Just in time  {-)
EDIT
gallery link https://techno.smugmug.com/Shannon/13-15-Stem-head-bow-roller/n-WpBgrf/
ANDY
Taranis
  • Balne Moor MBC
« Reply #510 on: December 30, 2019, 07:31:42 pm »
Ready for primer
ANDY
kinmel
« Reply #511 on: December 30, 2019, 07:42:51 pm »
The problem is that all crews have now been issued with the appropriate "Helly Hanson" kits, which bears no resemblance to any of the scale figures available.
https://www.google.co.uk/search?q=helly+hansen+lifeboat+jacket&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjXw5CIkN7mAhWOQkEAHQUwC7oQ_AUoAnoECBYQBA&biw=1920&bih=916#imgrc=nAFuYRtlhipuLM:
Taranis
  • Balne Moor MBC
« Reply #512 on: December 30, 2019, 07:45:58 pm »
That won't be one of my concerns Alan, I'll be very happy to have well painted figures in previous kit.
ANDY
Taranis
  • Balne Moor MBC
« Reply #513 on: December 31, 2019, 11:12:28 am »
Another set of photos from JH covering the 13-15 anchor. Unlisted gallery so download or bookmark them.
https://techno.smugmug.com/Shannon/13-15-anchor/n-RCNLVf/
ANDY
Taranis
  • Balne Moor MBC
« Reply #514 on: December 31, 2019, 12:22:20 pm »
These are the closest I can find for the port starboard nav lights.
Tamiya clear colour applied inside. When the exterior black is applied they should be acceptable.
I'm not doing working lighting for a number of reasons. In the event of damage to the mast structure mine is easy to dismantle to repair, wiring would make it a real chore.
Some examples I've seen are far less desirable to me than a crisp clean wire free build.
So at nearly £12 a set its an expensive way of procuring the two lenses I want.
ANDY
Taranis
  • Balne Moor MBC
ANDY
Taranis
  • Balne Moor MBC
« Reply #516 on: December 31, 2019, 04:06:02 pm »
They'll do for me
I've used Halfords appliance white on this.
I'll allow full hardness before fitting the FURUNO decal
ANDY
Taranis
  • Balne Moor MBC
« Reply #517 on: January 01, 2020, 08:36:29 am »
Happy New Year Shannon modellers .
My only resolution is to finish this build before 2021  {-)
Not unrealistic  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #518 on: January 01, 2020, 10:12:24 am »
No mistake with this, the largest size milled Z that Knupfer stock. I bought it in the hope ....
0.8mm drill 1mm tap M1 x 3mm screws
ANDY
Taranis
  • Balne Moor MBC
« Reply #519 on: January 01, 2020, 02:41:45 pm »
Unfortunately for other modellers this ratchet is now discontinued by RC4WD
Also one issue is that it will not release tension so must be made demountable once tension is applied if you need to remove the bow cable.
ANDY
Taranis
  • Balne Moor MBC
« Reply #520 on: January 01, 2020, 04:54:01 pm »
Radar finished
<iframe width="560" height="315" src="https://www.youtube.com/embed/f753umCEzSg" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
ANDY
Canterbury Coxswain
« Reply #521 on: January 01, 2020, 04:59:10 pm »
Just wonderful! %%
Kim
Taranis
  • Balne Moor MBC
« Reply #522 on: January 01, 2020, 05:42:11 pm »
Thank you much appreciated. :-)
Been a good day
ANDY
Taranis
  • Balne Moor MBC
« Reply #523 on: January 01, 2020, 10:30:59 pm »
The anchor plinth took no time really but it spurred me on to make the Hydraulic pipe protector. I've yet to see one that looks like it so I've copied pictures from 13-15
This was two profiles cut to shape, 2mm sitting on 1mm then 4 x 1mm pieces for the fixing points.
ANDY
Canterbury Coxswain
« Reply #524 on: January 02, 2020, 01:36:23 am »
Andy,
Folder 2 on second DVD of photos, and especially for the SeaCatch when it comes!!
Kim
