Author Topic: Paint over fiberglass  (Read 3853 times)
cdnfurball
  • Success = a model boat that floats
« on: April 17, 2019, 03:07:44 am »
Hoping your experience can help a nubee.    My hull is planked, sealed and sanded 2 part epoxy. Then l used 3/4 oz fiberglass laid with the 2 part epoxy again.   I am wondering the best type of paint for the hull.    Thanks
People come & go in life. Some leave memories......
Re: Paint over fiberglass
« Reply #1 on: April 17, 2019, 08:14:27 am »
I use plastic undercoat and car spray paints with no problems. One boat is nearly 20 years old.  :-))
nemesis
« Reply #2 on: April 17, 2019, 09:30:40 am »
use a plastic primer first, nemesis
cdnfurball
« Reply #3 on: April 17, 2019, 11:13:00 am »
Thank you for the guidance.      What do you mean . " Plastic undercoat " ?
I have found in these forums, pending where on this plant you are located,  terminology can be different.
JimG
« Reply #4 on: April 17, 2019, 12:47:55 pm »
Basically a primer paint intended for use on plastic parts in cars. e.g. car bumpers. (In the USA read fenders) It should bond better than a primer intended for metal.
Jim
Dundee Model Boat club
NickelBelter
« Reply #5 on: April 17, 2019, 01:33:57 pm »
Here in Canada you can find Krylon Fusion paints which supposedly bond to plastics better than regular spraypaint.  Any spray primer will work just fine too.
nemesis
« Reply #6 on: April 17, 2019, 07:43:32 pm »
Plastic primer etches the surface of the plastic or gel coat of a laminate therefore enabling the following coats to bond, done properly it is very difficult to scrape the paint off the surface. nemesis
coch y bonddu
« Reply #7 on: April 17, 2019, 11:44:12 pm »
Tbh you dont really need a plastic primer at all,this is simply because it is not plastic at ll but Grp,if you are at all afraid the primer will lift with I know it will not then in Halfords they sell an etch primer,apply this first then primer afterwards,in all the years of preparing grp panels for cars boats and actually planes I have never had paint peeling just using a normal primer,preparation is the key to success.30 odd years of painting experiance tells me this  O0 O0 O0 O0 O0 O0
« Reply #8 on: April 18, 2019, 03:02:30 am »
Thats what ..my dear old Dad always said......"[/size]a good paint job all in the preparation![/size]" O0 .................. Derek
