Author Topic: 1/32 oerlikon  (Read 3560 times)
ether823
1/32 oerlikon
« on: April 28, 2019, 03:12:50 pm »
Hi, anyone know where I can get some plans for 1/32 oerlikon single and double guns. I`m building a 1/32 RAF LRRC ex Fairmile D type MTB Many thanks, Peter
Liverbudgie2
Re: 1/32 oerlikon
« Reply #1 on: April 28, 2019, 03:56:33 pm »
Try Models by Design or Shapeways.
LB
tonyH
Re: 1/32 oerlikon
« Reply #2 on: April 28, 2019, 05:46:33 pm »
Try this http://archive.hnsa.org/doc/gun20mm/index.htm for the single and http://archive.hnsa.org/doc/gun20twin/index.htm for the twin but beware of the variation in mounts.
Tony
ether823
Re: 1/32 oerlikon
« Reply #3 on: April 28, 2019, 06:34:07 pm »
Thanks guys but I need scale drawings. Regards, Peter
raflaunches
  • The Penguins are coming!!!
Re: 1/32 oerlikon
« Reply #4 on: April 28, 2019, 06:47:58 pm »
You’re probably not going to get drawings in the scale you need but rather get a drawing and then take to a print shop to get them rescaled for you.
If you can find some of the older John Lambert drawings I believe he drew up an Oerlikon in the different styles you require. Failing that I’d recommend finding a copy of The Anatomy of the Ship book The Fairmile D which should have the Oerlions drawn in three different views but probably in a smaller scale (I think 1/48 or smaller). The Anatomy book does show a lot of information on the Fairmile boats and a lot of extra detailing that you might be interested in.
Nick B
Illegitimi non carborundum!
raflaunches
Re: 1/32 oerlikon
« Reply #5 on: April 28, 2019, 06:52:08 pm »
Failing that just seeing the prices of the anatomy book on Amazon I recommend getting a copy of the latest edition of Allied Coastal Forces of WW2 Volume 1 which should have the same drawings in them but you might have to find out the scale first.
Nick B
Akira
Re: 1/32 oerlikon
« Reply #6 on: April 28, 2019, 11:13:47 pm »
Anatomy of a Ship Series. Any of the USN Fletcher class destroyers should have plans for the Twin mounts. I also have the twin mount pamphlet put out by Floating Drydock which I can scan and send to you, but it will be a few days before I get home. There were numerous configurations, mostly relating to the mounting, so being specific helps.
TailUK
Re: 1/32 oerlikon
« Reply #7 on: April 29, 2019, 09:01:42 am »
Conways; Allied Coastal Forces of World War Two - Vol 1 and 2 by John Lambert and Al Ross have drawings of all the weapons and drawings of the LRRPs as well.
redpmg
Re: 1/32 oerlikon
« Reply #8 on: April 29, 2019, 09:12:32 am »
Believe that David Metcalfs plan for A HDML has a good drawing on it. I have two copies of the plan and a digital one . Send me a pm to cofirm you still need the drawing. Its probably a different scale  but can adjust that for you and send as a pdf or jpg. That is of the oerlikon by itself , very easy with Corel.
redpmg
Re: 1/32 oerlikon
« Reply #9 on: April 29, 2019, 12:32:26 pm »
Found both plans - will post small scale later - full size will need to go to email
ether823
Re: 1/32 oerlikon
« Reply #10 on: April 29, 2019, 12:43:25 pm »
Thanks for the replies gents, great ideas. regards, Peter
gerritv
Re: 1/32 oerlikon
« Reply #11 on: April 29, 2019, 08:16:52 pm »
The newly published British Naval Weapons of WW II Vol 1, the John Lambert Collection has a lot of his drawings but not the Oerlikon one. I suspect/hope it is in Vol 2 due in Aug this year.
I have a copy of L/0/82 that I bought from John Lambert in 2013 or so. But it is of the Oerlikon gun only, no mountings.
The recently published book The Life and Ship Models of Norman Ough does have the single and twin mountings drawn by him on page 30.
Gerrit
I attached 3 views of the twin mount located at HMCS Haida in Hamilton just west of me.
ether823
Re: 1/32 oerlikon
« Reply #12 on: April 29, 2019, 08:49:05 pm »
Many thanks everyone
mudway
  • Model Boat Mayhem is Great
olly4950
Re: 1/32 oerlikon
« Reply #14 on: May 01, 2019, 06:51:51 pm »
Battlecrafts
Onetenor
Re: 1/32 oerlikon
« Reply #15 on: May 02, 2019, 10:06:15 pm »
One tenor in dock 2 weeks now. Don't know if I said I totally smashed right femur. Now repaired and hip replaced at same time What I wanted but not the way to go about it {:-{  OOOUCH! 4 more weeks none load bearing yet.
Page created in 0.035 seconds with 18 queries.
