Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 565334 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #950 on: May 19, 2021, 08:27:12 pm »
frogman3
« Reply #951 on: May 19, 2021, 08:28:54 pm »
https://ibb.co/sQQwwDR
an now soon in the test tank for water tests
T888
« Reply #952 on: May 19, 2021, 09:23:42 pm »
Paint job looking good Chris :-))
Regards David
frogman3
« Reply #953 on: May 20, 2021, 09:28:42 am »
CHEERS Dave  :-))  just got to leave it a few days for the paint to harden off an then need nice wheather an she will be in her water test tank for testing
chris
frogman3
« Reply #954 on: May 28, 2021, 07:43:35 pm »
HI ALL JUST A FEW PICS ON WHAT IVE BEEN DOIN ON HER WHILE I WAIT FOR BETTER WHEATHER TO DO A WATER TEST  >>:-( <*< :-))
ANY WAY ANKORS FITTED
https://ibb.co/NjJZBdH
frogman3
« Reply #955 on: May 28, 2021, 07:45:09 pm »
AN  LOVE TO SEE THEM DANGLE ON THEIR CHAINS
https://ibb.co/6PhzRSK
frogman3
« Reply #956 on: May 28, 2021, 07:45:55 pm »
frogman3
« Reply #957 on: May 28, 2021, 07:46:48 pm »
frogman3
« Reply #958 on: May 28, 2021, 07:50:15 pm »
AN I JUST PUT  HER TOGEATHER AGAIN NOW SHE HAS GOT A BIT OF COLOUR ON HER HULL
https://ibb.co/ByHcY85
frogman3
« Reply #959 on: May 28, 2021, 07:50:58 pm »
frogman3
« Reply #960 on: May 28, 2021, 07:51:54 pm »
frogman3
« Reply #961 on: May 28, 2021, 07:52:34 pm »
T888
« Reply #962 on: May 28, 2021, 08:14:17 pm »
She Huge, but coming long nice build Chris  :-))
Regards David
frogman3
« Reply #963 on: May 28, 2021, 08:36:44 pm »
HI Dave yea she is a biggy isnt she lookin forward to putting her in the test tank over wk end if nice weather
chris
frogman3
« Reply #964 on: May 28, 2021, 09:52:19 pm »
THANK YOU Martin for bringing up my pics  :-))
cheers chris
frogman3
« Reply #965 on: May 30, 2021, 08:00:06 pm »
HI ALL UPDATE ON WATER TESTS
[/size]an i put her in the test tank an loaded her down with about 30 pounds of batts an after half an hr she had two tiny bubble leaks in her hull[/color][/size]
so took batts out an took her out of the tank an then just poured in some resin over the small areas an then back into the tank an put back in the batts an she was ok for near about 3hrs in the tank an no more leaks im pleased to say an the shock test went ok as we lift her up an give her a shake with a big batt in the centre of the hull an jen said no cracking sounds so that test passed ok
[/color][/size]an stabilty was reasonable but i think im gonna fit a keel weight on her as i dont want to have to fit all those big batts in when i sail her so the keel wheight will be the way to go SO IN OTHER WORDS SHE PASSED HER TESTS OK an now some picces but they are not that good as over the yrs livin here jen has fitted around my test tank a lot of bushes an plants so i could not get right down to take pics of tiger in the tank an i took about 80 pics an here now ive just picked out the best ones an they are a little blured as the sun light was so bright on the white plasti card super structure it caused a little light reflection so my auto camera cut down the light so not so good picsanyway 1st picces just in the tank an no batts weghts in her as i just wanted to see how she floated
https://ibb.co/94qjHG8[/size]
frogman3
« Reply #966 on: May 30, 2021, 08:00:47 pm »
frogman3
« Reply #967 on: May 30, 2021, 08:02:07 pm »
shot of the really heavy batts
https://ibb.co/d7NQT5P
frogman3
« Reply #968 on: May 30, 2021, 08:09:32 pm »
here the two areas where she had tiny leaks  >>:-( <:(  an just poured on some resin  an more leaks  <*< i thought that she would leak in about a dozen places but i was surprised  :-))  one tiny leak in the stern section as you can see where by the orange resin
https://ibb.co/r5mpLm1
frogman3
« Reply #969 on: May 30, 2021, 08:10:37 pm »
an other leak in the front right nr the bow thruster
https://ibb.co/r4KWZz1
frogman3
« Reply #970 on: May 30, 2021, 08:12:59 pm »
an with all four heavy batts in to do a water pressure test
an it pushed her down to about half way on her black water line
https://ibb.co/m5MHLtY
frogman3
« Reply #971 on: May 30, 2021, 08:14:12 pm »
frogman3
« Reply #972 on: May 30, 2021, 08:16:39 pm »
some shots here with her S/S ON BUT no heavy masts yet
https://ibb.co/NyJxMfZ
frogman3
« Reply #973 on: May 30, 2021, 08:17:31 pm »
frogman3
« Reply #974 on: May 30, 2021, 08:18:13 pm »
Page created in 0.163 seconds with 18 queries.
