Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 593054 times)
JimG
Re: Chris' HMS TIGER (C20) - 1:72 SCALE
« Reply #2325 on: September 29, 2023, 08:35:27 pm »
Check the alignment of the motor and shaft, if it is slightly out it might put a side load on the shaft and increase friction causing it to heat up. When fitting the motor to the tug I am building I used a 3D printed tube to replace the coupling and it seemed to be well lined up. On testing the motor it was running warm off load and the shaft bearing was also heating up. After moving the motor forward and fitting a double coupling everything now runs cool. Everything felt free running with the original setup and single coupling.
Jim
Dundee Model Boat club
frogman3
« Reply #2326 on: September 29, 2023, 08:40:02 pm »
Hi Chris,
Just don’t under stand it. Some questions
So is it just one of the shafts that is getting hot ?
If so is it the one that broke the UJ ?
I assume it’s just the steady bearing that’s getting hot ?
Am I correct in assume that all shaft spin freely?
[/quote
HI DAVE YES on all 4 qeustions
AN yes you are right bob
but to hell with it im just  gonna sail her at half throttle an see if it happen again as i have a spare s/s prop shaft so if there is somthing up with that prop sharft then i'll knock it out an fit n the new shaft
but this will be the last resort
chrisb
minimariner
« Reply #2327 on: September 29, 2023, 09:04:43 pm »
            Hi Chris,
                          In one of the photo`s the thread looks slightly to long, the thread needs to be no longer
                           than the brass UJ insert, if its to long it may rub on the centre brass UJ joint part.
                           Taking washers off would make it screw in further. Just a thought.
                               Bryan.
frogman3
« Reply #2328 on: September 29, 2023, 10:14:25 pm »
            Hi Chris,
                               Bryan.
HI Bryan
thanks for your reply but lookin at it close up the prop shaft is not touchin the center brass in the U/J where the heat is is in the brass couplin  that connects to the prop shaft as ive just been able to hold it when stopped an takin that washer off would only make it 1mm longer so i should not think this is the problem
CHEERS Bryan
chrisb
frogman3
« Reply #2329 on: September 30, 2023, 05:32:31 am »
HI Bryan
CHEERS Bryan
chrisb
i think the prob may be the prop shaft perhaps the bearin have broken or it grease inside as dreid up so im takin the prop shaft right out an rescirtin new grease into the tube  then refittin the shaft an try that
cheers guys
chrisb
T888
« Reply #2330 on: September 30, 2023, 08:33:37 am »
Morning Chris,
Can the steady bearing be removed, so you can check it for wear, any damage and alignment check.
ATB to you and Jen  :-))
Regards David
frogman3
« Reply #2331 on: September 30, 2023, 09:07:43 am »
Morning Chris,
i dont know yet Dave as im goin to have a look at it today  as the bad shaft is on the far side on the hull an due to the size of the hull i cant see it but when running the motors yesterday i found that shaft was vibratein so today im goin to have to angle the hull on the table so i can see that prop shaft better an withdraw that shaft an have a gander an if it looks ok then i'll refill it with new grease an if that dont cure the prob then i'll have to try an take out the shaft an fit a new one
ATB Dave
chrisb :embarrassed: >>:-( <:( <*<
T888
« Reply #2332 on: September 30, 2023, 11:29:49 am »
Good luck hope it goes well. :-))
Regards David
frogman3
« Reply #2333 on: October 01, 2023, 01:33:27 pm »
Jim
HI Jim alinement of motor looks ok an cant move the motor as no room but thanks for your info  on the subject
chrisb
frogman3
« Reply #2334 on: October 01, 2023, 01:34:19 pm »
AN CHEERS Dave
chrisb
frogman3
« Reply #2335 on: October 01, 2023, 08:35:12 pm »
HI GUYS well today ive tried to cure this U/J HEATING UP by removein the 16" long prop shaft an regreasein the shaft an the refitted it in an ran the motor an shaft for 5 mins at half throttle an it dint get warm so fingercrossed ive made it better but will only know for sure when she sails again on sunday october the 8th[/size]cheers all
chrisb :-))
[/color]
« Reply #2336 on: October 09, 2023, 05:01:08 pm »
I hope you had a successful sail?
frogman3
« Reply #2337 on: October 09, 2023, 09:21:05 pm »
[quote author=ballastanksin
HI GUYSwell yesterday took Tiger up for her forth sail an it was a beautifull day nice an warm but not as hot as last time an the modifications i have made to Tiger seemed to have worked very well as she was sailin just great an did not blow them 40 amp fuses so great i thought she's a success but then something strange happend i noticed that when sailing ahead the outer props went into full astern while the rear props kept goin ahead an i was practically pullin my hair out now whats wrong i thought an all i can think of is one of them ESC is playin up as i first thought it might be the R/X given the ESC false signals so i fitted a new spare R/XAN then treid her again an yes she's goin great really good propwash very powerfull an she surgerd ahead an was sailing great an i gave her some full head flank speed an she sailed again   i was very pleased but then to my amazement it did the props ahead an outer props in astern AGAIN SO right today im goin to remove that ESC that works the outer motors an have all 4 motors goin through just ONE ESC an it should be able to take the power current load as its rated at 320 AMPS an also i think i need to fit in a bigger one qauter scale heavy duty big servo to work the rudder an stablilizers as she dint answer the helm properly when under ahead forword so more cost buyin one of them but i think im gettin her right its just the gremlins to get rid of as i was very pleased at how she sailed when sailin ahead so im gettin there slowy an not givin up its just a matter of getting it all right OH DEAR an i'll fit some pics of the day tomorrow as gettin late now  :-) :-)) so i think i will need a bigger qauter size servo on the rudder anyone know what the number is for one ?chrisb
« Reply #2338 on: October 09, 2023, 10:39:49 pm »
That is progress Chris! No more searching for issues and having to rebuild gubbins, just (all being well) a modification to control, and she's off to the races!
« Reply #2339 on: October 09, 2023, 11:13:35 pm »
Well Chris, I'm glad you were able to give her another set of trials, but oh, I wish I had remembered you were sailing on the 8th - I've just been in East Dereham since Thursday night and just got back home at 1600 today!... and home is all the way up in Northumberland!
What a crazy journey that was... Anyway, I just hope you get them electrical problems sorted and maybe I can get back down that way sometime so I can see Tiger up close.
Cheers,
T888
« Reply #2340 on: October 10, 2023, 05:21:21 am »
Hi Chris
Both pleased and sorry for you that Tiger sailed well, but with ESC issues, so  >>:-( >>:-(
Howels Models do this servo, bit pricey at £38.99
The HS-805 uses a heavy duty nylon gear train and a heavy duty 10mm 15 tooth output shaft. The HS-805BB develops enough torque to move just about anything, be it a big plane, boat, or Car.
I found this on eBay.
https://www.ebay.co.uk/itm/324017324641?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338749368&toolid=20006&customid=GB_220_324017324641.140118387062~1871005637659-g_EAIaIQobChMIz7Lv9c_qgQMVg7jtCh0DrgWREAQYBiABEgImPfD_BwE
Regards David
frogman3
« Reply #2341 on: October 10, 2023, 07:49:30 am »
HI well there was a few isuses regardin hanger bay door not working an a couple of small things im not happy with %) O0 [size=78%] so im goin to sort these out over the comin week but overall yes she could be ready for another sortie thanks for your reply [/size]
chrisb :-))
frogman3
« Reply #2342 on: October 10, 2023, 07:56:20 am »
Cheers,
AN HI  Ray  yes thats a pity as you was fairly close an youre welcome to come an see Tiger as she an my hms norfolk will be in a 2 day show
at lowestoft on 28th an 29th   of this month will put on a poster soon for the show
ATB chrisb
frogman3
« Reply #2343 on: October 10, 2023, 08:01:06 am »
Hi Chris
AN Many thanks dave for info on that servo as i feel fairly sure that the normal servo is not up to the job as when turning she dint turn well
cheers
chrisb
frogman3
« Reply #2344 on: October 10, 2023, 08:28:52 am »
AN now for some linkpics of the day an jen an i arrived early at 8-30 am an it was nice wheather no wind an warm sun an several boatys turned up as you can see by the cars there
https://ibb.co/23WQXzX
an here just unloaded her from the car an put her alltogeather on her table
https://ibb.co/27bpKWH
AN on the table i had the lowestoft model show poster out an several people were usein phones to photo it so hope they will attend the show
 https://ibb.co/XXfRm6C
an now here she has just been lifted in the water for tests
https://ibb.co/9Ytmdk8
an some other boats with her
https://ibb.co/Qv7qV1z
frogman3
« Reply #2345 on: October 10, 2023, 08:32:21 am »
AN While i was doin the testing of functions my m8 paul took some close  up pics of her
https://ibb.co/hYqTbBm
https://ibb.co/hdc02sb
https://ibb.co/2jBpjm9
T888
« Reply #2346 on: October 10, 2023, 08:35:00 am »
She does look nice :-)) :-))
Regards David
frogman3
« Reply #2347 on: October 10, 2023, 08:38:43 am »
AN now testin completed she is now gettin underway as can be seen by the propwash an this was at half throttle  O0
https://ibb.co/FYqGc2H
an then i just stopped her as some people wanted to take photos
https://ibb.co/LCkFHqd
https://ibb.co/L6Jstbk
https://ibb.co/0Xy5KsR
AN SORRY pic a bit blurred as i had just switched on the smoke unit
 :embarrassed: O0 {:-{
frogman3
« Reply #2348 on: October 10, 2023, 08:39:49 am »
CHEERS Dave glad you think so Sir
chrisb
frogman3
« Reply #2349 on: October 10, 2023, 08:45:15 am »
an a nice steamy tug standing by lol :}
https://ibb.co/8XLJb62
an sorry again here she is sailin ok but jen took the pics but she dont know about zoomin in on the pic so TIGER is fairly small but she is a fair way away
https://ibb.co/y88bBt7
an headin back again
https://ibb.co/QKDTwzy
