Author Topic: which motor  (Read 2315 times)
madboats
which motor
« on: November 24, 2019, 10:29:38 pm »
Hi all. Just about to start to build my Sir Lancelot from Mountfleet. I am wondering what size motor I should use be it brush or brushless,
I am not concerned more of what size would be suitable. I have had a  look through some of the posts on Sir Lancelot but couldn't find any
mention of motor size. Thanks in advance
Regards madboats
unbuiltnautilus
Re: which motor
« Reply #1 on: November 25, 2019, 07:55:28 pm »
http://www.jotika-ltd.com/Pages/1024768/Fittings/CEM900T.htm
This would be my choice, it's like an MFA Torpedo 800, but with manners!
Buccaneer
Re: which motor
« Reply #2 on: November 25, 2019, 08:11:04 pm »
I have built 4 Mountfleet Kits and use either a Mabuchi 555 or Mobile Marine Models T12. The 555 is listed at £9 from Component Shop, without mount, whereas the T12 is £47 with mount. Considering the size of the Sir Lancelot I would go for the T12. I consider it a superb motor, quiet, bags of torque.
It may seem expensive but, as often been said on this forum, when you spend a lot of money on a boat don't skimp on a cheap Chinese motor. Lancelot is going to work out at four figures by the time you have electrics and paint taken into account so I would not skimp and save £20 or so on a motor.
Re: which motor
« Reply #3 on: November 25, 2019, 10:53:30 pm »
Must agree with Buccaneer here  :-)) .....if you were to also bring motor current draw into the total electrical equation, the T12 motor will essentially lower the overall requirement/cost and provide inherent reliability with increased running time duration over a 555 Series motor
The T12 motor is also well suited to a larger slower vessel you propose....
Newer design, smaller, quality engineered cost effective, higher speed, lower torque etc, etc brushless motors are an excellent choice for many applications, but not a Mountfleet Sir Lancelot
No need for a 16 page technical evaluation analysis between the 3 different style motors.....just think about the old Chalk & Cheese adage..... O0
