Author Topic: Need help finding blue foam for shaping a hull master?  (Read 8147 times)
Voyager
« on: October 05, 2007, 04:50:57 pm »
Just need some info on the above, not sure where i can get some? Plus any tips when using the stuff, fancy scratch building a small 300mm hull but don't where to start?
Any advice would be greatly received ;)
Regards: Voyager
bigH
Re: Need help finding blue foam for shaping a hull master?
« Reply #1 on: October 06, 2007, 12:43:18 pm »
Hi Voyager, try www.craftfoam.co.uk/craftfoam.htm      Thats where I get mine from, they are cheap and fast.    H
Guy Bagley
« Reply #2 on: October 06, 2007, 01:06:15 pm »
try your local building supplies place, they often sell  huge sheets of the stuff, both blue and pink in colour for cavity wall / insulation filling, -
 the big DIY stores like wickes may also do it, - i get mine from the builders merchants at the end of my road, i have also been lucky in the past and got broken sheets for free, or the price of a pint... damaged so they can be sold but still plenty big enough for model use....
 tips are use a mask when cutting it/ shaping/ sanding,- the dust is bad news for the lungs !
cuts with bread knife, hot wire and can be easily shaped wih a surform.
  it will glue with PVA, it takes a while to dry or you can use solvent free building type adhesives ( like no nails stuff- but it must be solvent free)- or you can use double sided carpet tape for temp to semi permanent fixings.
 good luck , its good stuff to work with
philk
« Reply #3 on: October 06, 2007, 04:53:05 pm »
voyager where are you i have a couple of sheets of it in my loft
im in kent if any good
phil
Voyager
« Reply #4 on: October 06, 2007, 10:04:56 pm »
Thanks for the advice everyone O0
I live in Stanmore, roughly 10min from Wembley Stadium. I don't need much, the boat hull i have in mind will be only 300mm long! Is it something you can post Phil?
philk
« Reply #5 on: October 14, 2007, 10:59:29 pm »
i can post it but it's a bit bulky. as your in stanmore try ruislip at sheffield insulation. they should have bucket loads of it and hopefully some broken bits you can get for nix.
if you can't find the number locally i'll get it for you.
phil
Voyager
« Reply #6 on: October 16, 2007, 02:56:53 pm »
If you can send me the number then that would be great Phil O0 I can give them a ring and see what they have!
BlazingPenguin
« Reply #7 on: October 16, 2007, 03:09:54 pm »
B&Q do four 50mm sheets in a pack, I waslooking at it today for another project.
Voyager
« Reply #8 on: October 16, 2007, 03:28:09 pm »
Oh really ;) I have a B&Q just 10 min walk away from me, I'll check them out at the weekend and see what they have.
Cheers O0
andrewh
« Reply #9 on: October 17, 2007, 12:51:54 am »
Voyager,
I've never seen blue/pink or any extruded foam at a B & Q.  But  I have been to a sheffield insulation and talked to all the staff - they had several densities, thicknesses etc.
The stuff we use for model planes is Dow Floormate 200 (blue) but for your purposes any density greater than this would probably be better (300, 400 or 500)
Point is that when they discovered what it was for , and that damaged sheets were fine, they sold me one sheet and gave me several others and bits.  (Espace with no seats!)
I have a lifetime supply and slice it into planks, etc for all sorts of things (especially having discovered polyurethane glue!)
Its also used as a spacer for fork-lift pallets, and is thrown away -  ask at a builder's merchants
Voyager
« Reply #10 on: October 17, 2007, 01:02:18 am »
Thanks very much for the info O0 If i can't get a thick enough sheet for what i want then i can always glue sheets together from what i'm told? Where would i be able to purchase polyurethane glue? I had no idea about the different densities either, I'm pleased i'm finding all this out first before i go and buy the wrong thing!
andrewh
« Reply #11 on: October 17, 2007, 01:21:08 am »
PU glue - I get mine from a local carpenters supply shop - they sell both Gorilla Grip (the one the Americans rave about) and an unbranded one which works (for me) much better.
Also comes for Screwfix at extremely good prices and quick and cheerful service.
Notes about PU glue if you havnt used it:
Poisonous till set.  Hideously, and through the skin
Needs to be clamped a little till set - it expands to fill the gap by foaming
wet surfaces if you want speed
Use pvc tape to cover the outside of a joint so you don't have to clean it up
If you need a foam gap-filler froth a little up with water and pour it into hole
It cures by atmospheric water - so any open container eventually goes off - I get about 6 months
gingyer
« Reply #12 on: October 22, 2007, 05:16:02 pm »
HI there
I thought I saw that you could glue it together with
a hot glue gun no need to poison yourself.
Can you post a thread on how you get on please if it
works I may copy you for another project  ::)
Voyager
« Reply #13 on: October 22, 2007, 06:04:07 pm »
So long as i don't poison myself through the experience ??? Then i would be happy to start a thread on it Colin!
gingyer
« Reply #14 on: October 22, 2007, 06:25:29 pm »
that would be great I have read and heard of it being done but never
actually seen it being done and was considering using this method for a
project which I am considering
vosper
« Reply #15 on: October 22, 2007, 06:33:44 pm »
found this on ebay  Item number: 260172436747.
Voyager
« Reply #16 on: October 22, 2007, 09:55:22 pm »
Just purchased some from ebay, saves me the trouble of going out to get some....lazy "xxxxx" that i am ;)
Thanks for that Vosper O0
