Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17   Go Down
Author Topic: Andy's Amati Riva Aquarama build  (Read 83168 times)
Taranis
  • Balne Moor MBC
Re: Andy's Amati Riva Aquarama build
« Reply #125 on: July 19, 2020, 07:30:06 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #126 on: July 19, 2020, 07:35:27 pm »
I found the best method to remove the high spots was a small block of wood and P120 grit.
Sanding side to side across the grain works very well in the concave areas.
ANDY
Taranis
  • Balne Moor MBC
« Reply #127 on: July 19, 2020, 10:04:38 pm »
A modification to the bench seat. I found this was a fiddle to put in place without it falling through so I've added supports to both ends that now prevents this happening. I may yet remove the existing cross piece.
ANDY
Taranis
  • Balne Moor MBC
« Reply #128 on: July 20, 2020, 01:48:35 pm »
I went ahead and removed the bench seat support. This not only reduces weight but improves access especially with Allen keys
Also 2 x 40mm Helium points  :-))
ANDY
Nordlys
« Reply #129 on: July 20, 2020, 05:14:37 pm »
It would be very interesting to know the weight of the kit in box when you received it, and the final weight without hardware.
Your progress is impressive, seems to have gone faultlessly and the result so far has a look of quality about it.
The motor couplings interest me.
Nordlys,
DJW
« Reply #130 on: July 20, 2020, 05:59:13 pm »
Looking good Andy.  Good idea re the revised bench supports, think I need them too, as you say the access to the motors is improved too...  And looks like I need to find a big drill for that bench seat itself...
The supplied seats seem rather heavy, just saying...  Any plans..?  I'm thinking to rebuild in balsa then cover in the cream upholstery material. (I think Mike used cork to good effect.)
Best regards
David.
1/10th Aquarama Build - https://tinyurl.com/riva-aquarama
1/5th Aquarama Build - https://tinyurl.com/riva-aquarama2
Taranis
  • Balne Moor MBC
« Reply #131 on: July 20, 2020, 06:18:04 pm »
Personally I think the seats are OK and practical and should look the part when painted. I found that mine are not glued together very accurately but managed to separate the parts and re attach with CA. Maybe need a magnetic fixing in the end.
This part I noticed is an unwanted recess so I've filled it in with scrap.
This is now ready to plank but I need to upholster the cabin first.
Starboard is almost there sanding wise and the shape really is to marvel at.
ANDY
Taranis
  • Balne Moor MBC
« Reply #132 on: July 20, 2020, 06:37:37 pm »
Nordlys,
Thanks Nord
I guess the model will weigh about one fifth of the timber pack supplied
ANDY
Fastfaz
« Reply #133 on: July 21, 2020, 07:42:19 am »
Hi Andy,
     A bit of subject but did you sell the Spektrum DX6i transmitters? Being a Carpenter I'm well impressed with your woodworking by the way, keep up the good work.
           Cheers, Pete  :-)) :-)) :-))
Taranis
  • Balne Moor MBC
« Reply #134 on: July 21, 2020, 05:55:16 pm »
As per messages. Thanks for your applause  :}
ANDY
Taranis
  • Balne Moor MBC
« Reply #135 on: July 21, 2020, 08:15:57 pm »
Final hull lime wood plank fitted. Ready for a day of sanding.
ANDY
ukmike
« Reply #136 on: July 21, 2020, 09:03:19 pm »
Hi Andy.
Lovely planking  :-))  but the workshop is not it's usual pristine self. ok2 ok2
Is it sanded yet ?
Taranis
  • Balne Moor MBC
« Reply #137 on: July 21, 2020, 09:05:51 pm »
 :o   I've just cleaned it {-) A couple of hours should see sanding finished. Still to resin inside of port side and fit deck ply.
Thank you  :kiss:
Don't this look like an Alien?
ANDY
Taranis
  • Balne Moor MBC
« Reply #138 on: July 22, 2020, 09:30:01 am »
ANDY
Taranis
  • Balne Moor MBC
« Reply #139 on: July 22, 2020, 11:53:22 am »
Hermes delivered my Rustins brown Mahogany solvent based wood dye this morning.
I bought from Amazon £6.43 delivered.
https://www.amazon.co.uk/gp/product/B01186E8WK/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
I think it's the only part in the kit requiring this
I also bought 2 more of these huge long reach clamps. Price is ridiculously low at under £4
https://www.amazon.co.uk/gp/product/B0001P19OK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
ANDY
Taranis
  • Balne Moor MBC
« Reply #140 on: July 22, 2020, 01:39:35 pm »
I'm thinking I want to make louvre doors and forgo the cabin interior that is barely visible anyway  %)
ANDY
DJW
« Reply #141 on: July 22, 2020, 01:55:43 pm »
Hmm, maybe a helium balloon in there, I like it...
I'm going to leave it open as a sound box for a speaker, but not fit the forward cushion, as I agree its not going to be seen.
ukmike
« Reply #142 on: July 22, 2020, 02:30:12 pm »
Hi Andy.
I've done exactly that with the big one and as you say it's as dark as the Black Hole of Calcutta in there, unless you add some form of lighting, which I personally don't do anymore. The louvre doors solve the problem and if you mount them with magnets you can easily get into the front, though why you would want too I don't know, unless there is lots of wiring in there.
Mike.
Taranis
  • Balne Moor MBC
« Reply #143 on: July 22, 2020, 02:35:39 pm »
No wiring
I   D O N ‘ T do lights  {-)
Could you find some or a picture of yours please Mike
I’ve just made a cardboard template of the opening  :-))
ANDY
ukmike
« Reply #144 on: July 22, 2020, 03:04:17 pm »
No wiring
Hi Andy.
Can you elaborate on this, "Could you find some or a picture of yours please Mike"
Mike.
Taranis
  • Balne Moor MBC
« Reply #145 on: July 22, 2020, 04:05:17 pm »
Just a picture of your doors?
I've started with a cardboard template
Then transferred it onto scrap wood and made a frame
I may not have made the leafs tall enough  %%  but they want louvres attaching now or start again
ANDY
Taranis
  • Balne Moor MBC
« Reply #146 on: July 22, 2020, 04:50:49 pm »
MKII
ANDY
Taranis
  • Balne Moor MBC
« Reply #147 on: July 22, 2020, 08:09:13 pm »
I decided to only louvre the lower half, here right door is finished apart from more varnish.
Yes its a tip again  :embarrassed:
ANDY
Taranis
  • Balne Moor MBC
« Reply #148 on: July 22, 2020, 08:53:03 pm »
Half a days work  :o  I guess I need some handles
ANDY
Taranis
  • Balne Moor MBC
« Reply #149 on: July 22, 2020, 09:59:41 pm »
Quick tidy up and tomorrows work laid out  :-))  Extra air added having seen David's latest post  O0
I might rip out the cabin mahogany walls too apart from the front panel that seals off compartment two
ANDY
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17   Go Up
Page created in 0.255 seconds with 18 queries.
