Pages: 1 2 3 4 5 6 [7]   Go Down
Author Topic: Chris's Fairey Swordsman 33  (Read 43908 times)
ChrisF
  • What's my favourite cake!
Re: Chris's Fairey Swordsman 33
« Reply #150 on: March 09, 2025, 09:24:11 pm »
Thanks Bob and Kiyo.
Hoping to keep the progress going with these two.
Chris
DJW
« Reply #151 on: March 10, 2025, 12:35:08 pm »
Hi Chris
Great to see you back on the forum and busy building.  Hoping to see some of the fleet at Wicksteed this year for an outing...???
Very best regards
David.
1/10th Aquarama Build - https://tinyurl.com/riva-aquarama
1/5th Aquarama Build - https://tinyurl.com/riva-aquarama2
ChrisF
« Reply #152 on: March 10, 2025, 03:07:46 pm »
Thanks David. The problem I was having with seeing and posting photographs has been resolved fortunately.
Chris
ChrisF
« Reply #153 on: March 16, 2025, 07:07:53 pm »
Well, planking has started, I may be some time!   :-)
These could well be my only plank on frame builds so it's good that I'm doing diagonal and longitudinal planking. It's going to be two layers of 1/32" ply on the Fisherman and 1.5mm bass on the Faun. Enjoying it but it's going to be a slog on the Fisherman!
Tony, if you read this, not all Faireys are the same!  {-)
Chris
ChrisF
« Reply #154 on: March 28, 2025, 06:00:17 pm »
Planking is progressing!
Change of plan with the Fisherman as I'm now planning on the second layer being 1.5mm thick bass strip laid longitudinally as per the Faun though that is only having one layer. Been a good learning experience and if I was doing another plank on frame I would do things slightly differently. But I'm pleased with how the hulls are shaping up and with more work will get them how I want them.
Chris
ChrisF
« Reply #155 on: April 07, 2025, 08:29:27 pm »
Second layer of planking progressing on the Fisherman and that to the Faun and the balsa to the bow is now complete. Bit of final filling and then ready for lightweight cloth and Eze-Kote.
Chris
ChrisF
« Reply #156 on: April 25, 2025, 11:09:50 am »
Bit more progress on Faun. Mahogany transom and rubbing strips fitted and deck veneered. Few more coats of Eze-Kote applied to hull and sanded down ready for painting.
Chris
ChrisF
« Reply #157 on: May 10, 2025, 09:51:05 am »
Prop shaft support glued in and rudder coming along.
ChrisF
« Reply #158 on: July 23, 2025, 12:32:22 pm »
Martin - I keep thinking I must ask if you can change the title of this thread to Chris's Fairey Builds as the Swordsman was only the start!
Been making a bit more progress on the little Faun and the bigger Fisherman. With Faun I've made a start on the superstructure and hull interior and have got some primer on the hull bottom. With Fisherman building of the hull is finished and ready for Eze-Kote and lightweight cloth.
Chris
Pages: 1 2 3 4 5 6 [7]   Go Up
