Author Topic: motor gearbox combo  (Read 3922 times)
ministeve
  • washing the decks!!!
motor gearbox combo
« on: October 10, 2007, 10:27:37 pm »
I'm looking for a good powerfull motor gearbox combo for some tugs both are twin screw one has 50mm props the other has 70mm props. they both will be used for tug towing and thought you guys may be able to help as i usually go big and direct drive as some will know but want to try something new
thanks in advance
Steve
Re: motor gearbox combo
« Reply #1 on: October 10, 2007, 10:30:11 pm »
550 motors on 2 or 3:1 reduction gearbox (Model Slipway can supply) and run on 12 volts.
Ghost in the shell
« Reply #2 on: October 11, 2007, 12:08:40 am »
speaking of gearboxes, anyway of cutting down the growl of them?  obviously straight cogs they wont be totally silent, but if only I could cut the noise down on southampton
Go Nuclear!  you'll love it
HS93 (RIP)
  • I cannot spell , tough
« Reply #3 on: October 11, 2007, 12:10:16 am »
are you using gears or belts ?
Peter
Ghost in the shell
« Reply #4 on: October 11, 2007, 12:14:25 am »
standard cogged box, something like 3.4 to 4-1, pencil eraser sized input 2p coin sized output, plastic cogs, straight cut, sounds like a cat in agony
HS93 (RIP)
« Reply #5 on: October 11, 2007, 12:20:55 am »
Just change to toothed belt system
peter
Ghost in the shell
« Reply #6 on: October 11, 2007, 12:26:59 am »
easier said than done, its the southampton RTR, the gearbox is also the engine mounts, all you see of the motors is the contacts for the wires, and the cogs on the outside.
HS93 (RIP)
« Reply #7 on: October 11, 2007, 12:29:02 am »
post a picture if you can you may be able to change the internals.
Peter
Ghost in the shell
« Reply #8 on: October 11, 2007, 12:31:02 am »
Page created in 0.02 seconds with 18 queries.
