Author Topic: Another natural birdbox  (Read 1317 times)
davejo90
« on: January 23, 2021, 11:10:50 am »
Ok well I say 'another' because this is the second one I have made. I started it in the morning around 10.00ish and was finished in the afternoon by around 16.00.
This is the process
Drill holes and test insert the bolts. The bolts along with wingnuts will be used to hold on the bottom removable base to the access to the inside to clean it out if it's used.
Remove the bolts and saw off the bottom 25mm
Mark out the area to cut out
Start to drill out around the edge, this is the point where I wish I had a big lathe to turn it out
Drill a bigger hole to help the chopping out with the chisel
Start the cut out process
The end of stage 1 chopping out
The end of stage 2 chopping out
After a little tidy up install camera
Connect the camera cable and fix it to the shed
A potential tenant when they start nesting
Leaky Bottom
Re: Another natural birdbox
« Reply #1 on: January 23, 2021, 04:02:09 pm »
Very good, I think I may make one of those, need to look for a suitable log now :-))
raflaunches
  • The Penguins are coming!!!
« Reply #2 on: January 23, 2021, 06:38:12 pm »
When we took down our multi bird box last year to replace the rotting roof we were very surprised when we opened it up. We had never seen any birds using the boxes but obviously not! We nicknamed the boxes ‘Hotel Sparrofornia’! We like The Eagles! :}
If you look closely that there are multiple layers in each section indicating that for the ten years it was on the wall it was always in use. It’s safely been repaired and refitted to the wall for this years broods.
Nick B
Illegitimi non carborundum!
« Reply #3 on: January 23, 2021, 09:28:38 pm »
Hotel Sparrowfornia! We are an Eagles family as well. We have seen them twice, once at Twickers in 2005 and again at the O2 in 2014. They are a great live band.
The natural bird box is a good idea! I have a lathe, though it needs setting up etc but turning out some would be a good way to get back into it.
BrianB6
« Reply #4 on: January 24, 2021, 12:21:08 am »
A bigger entry hole and it would make a nice Possum home.  %)
