Pages: 1 [2] 3   Go Down
Author Topic: Amerigo Vespucci Panart 1/84 by Kevin started 2008  (Read 13328 times)
kevin547n
Re: Amerigo Vespucci Panart 1/84 by Kevin started 2008
« Reply #25 on: March 30, 2021, 02:09:11 pm »
slowly building up, no deck fittings are secured yet
Amerigo Vespucci -  Panart - 1/84
https://www.modelboatmayhem.co.uk/forum/index.php/topic,66456.0.html
I tend to do a lot of building at the weekends, then ponder what i have achieved during the week, then adapt, redo or accept the following weekend
kevin547n
« Reply #26 on: April 02, 2021, 08:50:23 pm »
good evening everyone
i redid the derrick mast, 40mm to long was something that was going to look a bit stoopid, one on the right is the correct length
[/size]the funnel has[/color][/size] been stripped back of colour [/color]
[/size]the stern railings are now in position, although the capping has still to be sanded down [/color]
[/size]the stern lifeboat davits have also been made up and inplace but not [/color][/size]fixed[/color][/size][size=78%]
[/size]
Mark T
« Reply #27 on: April 02, 2021, 08:57:58 pm »
Thats some lovely work there Kevin - keep the updates coming
kevin547n
« Reply #28 on: April 02, 2021, 09:04:39 pm »
thank you Mark
kevin547n
« Reply #29 on: April 05, 2021, 08:43:22 pm »
after deck awning stanchion
the instructions, say 40mm bend 5mm and hammer flat the last 2mm and drill  1mm hole in the flat bit x 12
must be a better way, so i took 35mm bend 5 and added a pintle on the end by soldering x 12, these will be added to the build this week, lol i see so many snag hazards later on with the rigging, im going to curse this so very much
i dont know what these look out posts are called, but again i have replaced gluing with soldering, there is not a lot of room for them, i will have to shorten the hand rail by a couple of mm
NOT MY PHOTO,
this is what i am trying to achieve
Bild_14.jpg.6a0709b2ccc1f2eba168305a274198bf.jpg.fda1bc210f324c5c9f81a3623a72babd.jpg
kevin547n
« Reply #30 on: April 26, 2021, 03:19:37 pm »
still working on my build, but as the warmer wether has turned up, getting the garden sorted out
all work presently is at the front end
« Reply #31 on: April 27, 2021, 07:54:57 pm »
Looking really good now, fantastic work  :-))
kevin547n
« Reply #32 on: April 27, 2021, 08:34:33 pm »
Thank you
kevin547n
« Reply #33 on: May 04, 2021, 08:36:34 pm »
on the lower part of the mast there is a coller  and 4 holes need to be drilled into it, and  pintles inserted  through which a wire hoop is fitted, this has hooks hanging from it an supports the cope coils from the pin rails  (Just below the awning)
this is the kit way
can do better i said
search light platform fitted
the radar according to the kit is hung below  main top in fact it is not and forms part of the planform
also other things are changing as i go along like extra holes on the top for lines to pass through
[why are parts of the mast painted white
Hande
  • Dream being fulfilled after 47 years.
« Reply #34 on: May 05, 2021, 04:48:39 pm »
Gasp! You have a proficient eye for detail and the skill to implement.
St Nectan is a beauty and Amerigo Vespucci takes my breath away with your detailed work.
Retirement - isn't it good..! I started my first and only build in early 2016 and I still fear that I'm not going to sail this year despite retirement last year and lock-down...
Trial-and-error doesn't spell failure - right?
kevin547n
« Reply #35 on: May 05, 2021, 05:36:16 pm »
thank you
i wish at times this was the Victory, i have as much time on the AV as i like, where as the Victory was weekend and holidays, it was suggested that i strip her back again and rework the rigging and put sails on
kevin547n
« Reply #36 on: May 06, 2021, 07:39:08 pm »
Good evening everyone
over the last couple of days the build table has been busy, the foremast lower sections are now complete i think, i keep finding new bits to scratch and add, the radar assembly requires a cage around it so i fabricated one, far better than the kit callout
today the main parts of the  bowsprit were made up on the lathe to fit the brass fittings
kevin547n
« Reply #37 on: May 24, 2021, 08:16:57 pm »
most of the foremast has been conpleted, there is enough for ,e to work out where the bowsprit rigging will go to
the bowsprit although not 100% complete is coming together, i am trying to make it look more realistic than the kit allows
yes i need to try harder
accommodation ladders
i binned most of the kit ideas and followed a guy on a German site
1826490418_Amerigo_Vespucci_ship_in_Haifa_(26)(1).thumb.jpg.e55da85042179971c849f6c346345333.jpg
im trying to achieve this
but not very well
kevin547n
« Reply #38 on: May 24, 2021, 08:18:13 pm »
she will be renamed in the near future, as the AV purists are giving me hard times over the green
willing for suggestions
dodes
« Reply #39 on: May 27, 2021, 11:20:21 am »
Thought this pic might interest you, taken from the Semaphore Tower in Portsmouth Naval Base when she visited in about 1991.
kevin547n
« Reply #40 on: May 27, 2021, 11:48:45 am »
thank you, she does look nice, but i still never realised how busy a ship she is
and LOL no green on her
dlancast
« Reply #41 on: May 28, 2021, 11:14:27 pm »
Just amazed at your skill and attention to detail.  What's to say about the green (I like it).... the purist will always have something to say if you don't follow the rules.  I built my "Ajax" English Frigate" per plan and kit.  It was not until later that there was a bunch of noise out on the forums that the "Ajax" never existed.  I decided just to not name my model and only call her a representation of an typical English Frigate.  Made me feel better.  In the end. You are the builder.  I decided that I want to donate 5 of my US Aircraft Carrier models to a nearby US Naval Air Station.  Being ex-Navy, I would be proud if they would accept them.  Waiting for an answer.   Too many models, not enough room.    Take care,  Dennis
dodes
« Reply #42 on: May 29, 2021, 03:06:23 pm »
With reference to frigate Ajax, No F114, built Cammell Laird and completed 11,12,63-1969 she was deployed Home/Far East.
dlancast
« Reply #43 on: May 29, 2021, 04:56:57 pm »
Confirmed and correct, modern day steel frigate "Ajax".  Also, there is record of an English Frigate "Ajax" of 1810-1864.  My comment was based on discussions several years ago, while I was building the model "Ajax" that there was question as to her existance.  I made the decision to not name my model, but just show her as an example of a military version of a typical English Frigate of 1850.  Dennis
kevin547n
« Reply #44 on: May 29, 2021, 06:57:23 pm »
thank you
i need to look out your Ajax i was thinking of that from the Euromodel site, but went for the CAF HMS Enterprise instead will get on with that when this is complete
dlancast
« Reply #45 on: May 30, 2021, 12:31:20 am »
Nice... true plank on frame.  Enjoy that one.  Dennis
kevin547n
« Reply #46 on: May 30, 2021, 08:54:05 pm »
she builds into nice size at 1/48, i just lost confidence in the building process as there are very few build logs and no books just the ATOS Pandora
dlancast
« Reply #47 on: May 30, 2021, 11:24:24 pm »
You know, the plans for the "Ajax" might work for that model.  They were noted to be one of the finest produced.  Sadly, I did not save my set.  Wonder if you can buy just the plans or even if the kit is still made.  Was it a Euro kit?  Too long ago.  Dennis
dlancast
« Reply #48 on: May 30, 2021, 11:33:28 pm »
Ok, here you go: https://forum.game-labs.net/topic/3058-hms-ajax-british-frigate-with-plans/   this link will bring back all the ugly comments about the "Ajax"...... now I know why I did not name my model.  It was the Euro kit and those are "some" of the plans provided in the kit.  It was difficult to build, took me 3 yrs., but did produce a nice model in the end.  Dennis
kevin547n
« Reply #49 on: June 06, 2021, 07:20:00 pm »
[/color]Good evening everyone[/size]
[/color]i think that the hull and fittings is now about 75-80% complete, every time i look at photos i see more to add, also now that im more confident with soldering, im  happy to have a go at making bitsthe accommodation ladders are now done, just the lifting gear/davits to be made up
Pages: 1 [2] 3   Go Up
Page created in 0.287 seconds with 18 queries.
