Pages: 1 2 3 [4] 5 6 7 8 9   Go Down
Author Topic: Billing Boats Nr 424 Mercantic cargo vessel.  (Read 48078 times)
Taranis
  • Balne Moor MBC
Re: Billing Boats Nr 424 Mercantic cargo vessel.
« Reply #75 on: July 06, 2021, 09:42:27 pm »
The days not over.
I wonder what everyone else did with their ribs aft of the bow?
I had a choice of breaking all the frames out and fitting new ones to scale or shaping them and accepting their over thickness.
I've chosen the latter and will fit thinner intermediate ones.
I've also started the stern gunwale
Just three ribs left to shape
ANDY
Taranis
  • Balne Moor MBC
« Reply #76 on: July 07, 2021, 02:15:11 pm »
Last night I glassed the Port side and this morning sanded it.
Then I prepared the Starboard half.
Once sanded the next job is to set the waterline.
ANDY
nemesis
« Reply #77 on: July 07, 2021, 08:07:12 pm »
Hi Andy, bit of an awkward job to do. You could have left them as they were, an accepted part of the kit or do what you did. What ever takes your fancy. That is it with a wood kit. Still doing a good job, lovely, bill
Taranis
  • Balne Moor MBC
« Reply #78 on: July 07, 2021, 10:48:25 pm »
Thank you Bill
Still hard to call
I may yet knock out the well deck ribs yet.
For now I’ll sand the rest of the of the hull and mark the waterline before cutting the long wash ports and adding the bilge keels and rubbing strakes
ANDY
Taranis
  • Balne Moor MBC
« Reply #79 on: July 10, 2021, 08:09:26 am »
Bildge keels fitted, waterline marked, wash ports being cut and gunwales in progress.
I hope to get some primer on the outer hull this weekend.
ANDY
Taranis
  • Balne Moor MBC
« Reply #80 on: July 11, 2021, 08:39:16 am »
Progress from yesterday.
Bow fairleads cut out
Two more frame ribs removed and replaced with eight new ribs.
Rubbing strakes fitted.
Coaming fitted around stern access
Bracket for aft lifting boom fitted
Favourite angle of view
Today I'll be making all the missing ribs
ANDY
Taranis
  • Balne Moor MBC
« Reply #81 on: July 11, 2021, 04:58:41 pm »
Change of plans but all progress.
I finished the ribs around the rear hatch.
I then was attracted to all the obechi offcuts.
Each panel is 1.5mm ply with planks glued on but removable for painting.
Then finally another use for the OSMO stain used on my Lobster boat.
I remember our friend DaveM asking me how to apply it.
Really easy as its just an oil. Brush cloth sponge whatever, put it on wipe it off until it looks ok to you. Then leave 12 hrs before applying clear coat.
Now ready for the game
ANDY
Taranis
  • Balne Moor MBC
« Reply #82 on: July 12, 2021, 05:52:00 pm »
I ended yesterday with making eight bases from brass strip for the bollards.
Billing do make this part but unfortunately they suffer from inconsistencies.
I then thought perhaps a start on the superstructure would make a nice change.
Base complete
It's essential here to have the correct relationship between the height of the deck cabin roof and the gunwale.
Making the walls is 10% inspiration 90% perspiration
For the next level, the bridge windows.
ANDY
Taranis
  • Balne Moor MBC
« Reply #83 on: July 13, 2021, 08:38:39 am »
Currently I'm making a template to match exactly the gunwales for the upper deck.
Also I'm going to shape the funnel today. Here I've made paper templates glued to the base as a guide. Thank you MarkT  :-))
The original instructions call for the port holes to be drilled after finished paintwork  {-)
That is a terrible idea as a mistake can mean a complete repaint  %%
Another IMPORTANT point is to avoid drilling on a bulkhead frame. If you stuck rigidly to the drawing this would occur!  Fortunately I had the foresight to avoid that potential disaster.
Resin coated to harden the balsa after rough sanding.
ANDY
Taranis
  • Balne Moor MBC
« Reply #84 on: July 14, 2021, 07:38:02 am »
Moving on. The paper template was turned into 1.5mm ply, oversize at this point.
All the while I'm considering how this will be painted, so as far as possible they won't be glued together.
ANDY
Taranis
  • Balne Moor MBC
« Reply #85 on: July 14, 2021, 01:59:25 pm »
So now the upper deck is trimmed to accept the wrap around. This is my new method off the cuff. Since having a Quooker tap fitted I see this as useful for more than hot drinks
The inner pipe is the radius I require and the outer half pipe prevents the outer skin splitting.
Two or three dowsings then tied and left to dry.
Still damp but it now has no resistance and no splitting.  I will give it a second treatment to be sure.
As this is a lot of work to cut out it would be folly to cut it first and then form the bend.
More later....
ANDY
Taranis
  • Balne Moor MBC
« Reply #86 on: July 14, 2021, 09:12:00 pm »
Forum seems unusually quiet, so todays third post.
Here is one side roughed out with the rotary Proxxon.
Honestly the template is quite inaccurate but as stated back in the 60's this model has to be built!! not merely assembled  O0
Rough fit
Underside
Not too shabby
Everything still comes apart for painting.
Tomorrow head start
ANDY
Taranis
  • Balne Moor MBC
« Reply #87 on: July 15, 2021, 08:18:48 pm »
Superstructure woodwork almost complete.
Component parts easy to paint and glaze.
ANDY
RST
« Reply #88 on: July 15, 2021, 08:35:22 pm »
The naval architecture in this boat is interesting.  Do you know why she was designed with the split level decks?  Was it so out-sized deck cargo could be carried on the forward hatch without compromising stability?  Maybe just a fashion of the time?
Am amazed at your mojo as usual.  To quote Star Trek 2 I think: "hours instead of days, days instead of weeks".  I've only got even slower at doing things over the last 18 months!
Taranis
  • Balne Moor MBC
« Reply #89 on: July 15, 2021, 08:47:31 pm »
Hi Rich, I asked the same question some time ago but cannot find the replies.
Basically its evolution. As a coastal cargo vessel she could deliver almost anywhere and the lower well deck and hold would have made it easier to load / off load at non ports. She's flat bottomed so she can anchor close to shore at high tide and wait for the low tide leaving herself high and dry. There is an archive photo of her fully loaded on top of the well deck hatch so there certainly wasn't any stability issues.
Edit
Outsized cargo is a good point you made  O0
ANDY
hama
« Reply #90 on: July 15, 2021, 10:26:17 pm »
Superb work as always!!
As for the well, as I tried to give an answer earlier  I'll try again.
A ship's tonnage is the enclosed volume and matters when it comes to regulations and fees. If you look at the picture of Mercantic with a full cargo you realise that had she had a full length main deck without the well, her total volume on the same length would be greater. She can still carry deckcargo on the full length of the vessel and load down to her deepest draft, but on a lesser volume.  There were as I understand a lot of vessels at 299GRT and 499GRT to avoid certain rules of manning for instance.
This is how I understand the design of the Mercantic.
But more important, carry on with yet another of your fabulous builds!!
Hama
RST
« Reply #91 on: July 15, 2021, 10:42:51 pm »
Hama
...great point Hama!  I forgot that, as you sat GRT is technically measured volume but in tonnage and not intuitive or much link in-between to the uninitiated.  All probably mixed in with tax rules and state rules rather than class rules.  A good point -a cheats way around things back then -the same happens today also.  It's all about tax!
I like Andys picture also.  The bulwarks are split at interesting sections I have a theory on but not qualified to comment.
nemesis
« Reply #92 on: July 16, 2021, 06:17:06 pm »
Hi Andy, We to have often wondered about that as well, coming,at times,  to consider that they were removable for easier access. It would be interesting to find out, keep up the good work, bill
Taranis
  • Balne Moor MBC
« Reply #93 on: July 16, 2021, 06:58:14 pm »
Thank you all for your comments and info  :-))
Last night I resin coated the superstructure and made the davits
Today I had to go to two branches of Halfrauds to stock up on satin lacquer and while I was at it I bought Ford Olympic Blue as recommended by Bill  :-))
After sanding the resin I coat all in Satin lacquer, a good leveller and baser for primer.
Funnel and davit fixings
Still lots to do
ANDY
Taranis
  • Balne Moor MBC
« Reply #94 on: July 17, 2021, 05:29:21 pm »
Far too hot today for modelling I know but aided by a fan and Italian white wine I have continued between glugs  {-)
Anyway pictures later of the limited progress
I know many of you refrain from Facebook for personal reasons but for those that do use it you can find me and all my (and others) daily updates there
Look for …  Andy and friends model boats
This is Public group so no need for membership and anything posted there can be shared and visible in any other group
ANDY
Stan
« Reply #95 on: July 17, 2021, 05:41:26 pm »
HI Taranis 90f in old money in Leeds 16.  Could you give me a call need some info.
Stan.
Taranis
  • Balne Moor MBC
« Reply #96 on: July 17, 2021, 08:07:10 pm »
My best friend today and I've just bought another one with mains adapter.
So I'm onto the littler things now starting with doors.
I need to buy some port holes for these.
These vent fittings I've stuffed with wood and drilled to take a servo rod.
The funnel looks odd without exhausts so I fitted a couple of pipes.
I'm not sure of some of these colours, Ice blue in particular.
ANDY
Taranis
  • Balne Moor MBC
« Reply #97 on: July 20, 2021, 06:47:50 pm »
For the funnel I decided on Ford Radiant Red
The top will be black eventually.
I decided I didn't like the hatch covers in only three sections as this would make the boards too heavy at full scale.
ANDY
Taranis
  • Balne Moor MBC
« Reply #98 on: July 20, 2021, 06:54:56 pm »
Moving on I continue catching up on ribs
ANDY
Taranis
  • Balne Moor MBC
« Reply #99 on: July 20, 2021, 07:03:11 pm »
Here I had to fix an earlier mistake. I wasn't looking forwards to tackling this but fears were unfounded.
Starboard completed.
ANDY
Pages: 1 2 3 [4] 5 6 7 8 9   Go Up
Page created in 0.027 seconds with 18 queries.
