Author Topic: Springer templates and other building advice...  (Read 19920 times)
azz126
Re: does anyone have any templates and other stuff or advice on them?
« Reply #25 on: December 11, 2007, 07:46:29 pm »
keep the stuff coming people its helping specialy the pics
Mr Andy
« Reply #26 on: December 15, 2007, 08:26:43 pm »
Well thanks to you lot, I have decided to have a go, I bought a workmate earlier and have cut the two sides, I realise now I should have cut the two together, never mind next one time.  ;D {-)
Arrow5
« Reply #27 on: December 16, 2007, 08:05:49 am »
Its an illness Andy, go to it and post pics.
..well can you land on this?
azz126
« Reply #28 on: December 29, 2007, 02:22:53 pm »
i cant wait to start mine
Bee
reference templates and rules
« Reply #29 on: January 18, 2008, 05:07:35 pm »
I notice Martin posted the plans at the start of this thread. Another thread recently questioned rudder size. Since these questions come up every couple of weeks wouldn't it be possible to have a Thread titled Plans and Rules with a single post on it with the info then locked and fixed at the top of the section. I did think I had seen this before but don't see it now.
This would also be straightforward for other websites to link to with advantage of publicity for Mayhem.
chingdevil
« Reply #30 on: January 18, 2008, 05:38:34 pm »
That is a good idea Bee, hopefuly Martin will see this thread or better still PM him with your idea. He does not bite well he did not the last time I saw him ;D ;D ;D
Brian
« Reply #31 on: March 19, 2008, 06:48:27 pm »
Plans: http://www.modelboatmayhem.co.uk/Common/Plans.doc
Right, I think these are the agred rules:
18" x 8" inch hull size and floor shape as per plan.
Single Motor up to 540 size ( gearing etc. allowed ) eg. 540/550 / Speed 600. ANY gear / belt / magnetic drive you like!
Power - Up to 7.2 volts
SINGLE RUDDER BLADE TYPE up 4" Sq.
Must have a superstructure of some sort.
You can fit steam if you wish,  jet turbines also allowed no IC or Diesel engines or Pulse Jets!
Arrow5
« Reply #32 on: March 20, 2008, 09:08:19 pm »
So we have "English Rules" then ? Why not stick to the original concept ?
Mr Andy
« Reply #33 on: March 20, 2008, 10:47:18 pm »
I know it's expensive but build one the way you want and another to compete, I may do so at a later date providing others in the club build some.
Andy. :)
banjo
« Reply #34 on: May 20, 2008, 11:38:17 am »
Where is the info giving sizes etc for the "Knees" ?  The sticky-out football playing bits??
tobyker
« Reply #35 on: May 20, 2008, 12:09:55 pm »
Arrow 5 - a bit late but that photo is ART, man.
chingdevil
« Reply #36 on: May 20, 2008, 06:05:27 pm »
Hi Banjo
The knees are the uprights at the front of the springer, the sticky out bits for football come from B&Q they are doorstops. I have attached a basic diagram of a knee. You can work from this, to be correct a standard springer should have its knees set at 7inch centres.
Brian
toesupwa
  • USA'd ex Brit
« Reply #37 on: May 20, 2008, 10:15:08 pm »
I extend the knees on my Springers down in to the bottom of the hull.. makes them a HELL of a lot surdier than just 'sticking them on' to the bow / deck.
banjo
« Reply #38 on: May 20, 2008, 10:24:36 pm »
 O0
tyvm
toesupwa
  • USA'd ex Brit
The long Build
« Reply #40 on: May 21, 2008, 07:21:36 am »
TYVM
Thank You Very Much  .... I think
banjo
Re: Springer templates and other building advice...
« Reply #41 on: May 21, 2008, 08:45:41 am »
 O0
Toes
Thank you very much........
alan
Arrow5
« Reply #42 on: May 21, 2008, 11:42:51 am »
Which one tobyker ?
nigel
« Reply #43 on: May 25, 2008, 11:26:34 pm »
   Hi Springer builders
        I used a product called bendy MDF available from the usual DIY sheds for the base of my springer.
        It did the job but it is fairly heavy,so some weight saving on other materials used.
        Saturday was great pity about to-day.
        Train driver.,
« Reply #44 on: May 25, 2008, 11:41:25 pm »
Maybe thiner MDF but having said that, my "Spring a leak every time" Springer has 2 6v 4Ah batteries and still need ballast!
