Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12   Go Down
Author Topic: 1/96 Scale T26 HMS Belfast build  (Read 83616 times)
frogman3
Re: 1/96 Scale T26 HMS Belfast build
« Reply #100 on: September 26, 2023, 07:40:20 pm »
Chris,
One panel size is 6.8 x 0.5 x 0.9 centimetres
WHATS that in ole money dave ?
chrisb
« Reply #101 on: September 27, 2023, 12:01:39 pm »
Anyone capable of 3d drawing could copy the principle and print to any dimension and adjust the shape of the runners to suit model warships.
I strongly suggest no one wakes the LEGO dragon by trying to sell them unless the design is based on a non copyright design principle? It looks like a simpler form that roller doors use......
Rob47
« Reply #102 on: September 27, 2023, 12:08:06 pm »
Same sort of principle as the roller door on my Leander except bigger panels
I will finish this model
T888
« Reply #103 on: September 27, 2023, 03:09:26 pm »
Too right Ian the Lego dragon would be jumping on anyone coping there design >>:-(
I’m currently looking at a slight mod to my design in that I need to have a curved section joining the two straight brass track section.
Regards David
T888
« Reply #104 on: October 02, 2023, 04:43:05 pm »
Gents,
Hangar door working, just need to fab up two curved section of track to stop the door sticking.
https://youtube.com/shorts/CQEXbwZNRMQ?si=ztH5G4yME8kEjdr3d
Regards David
Rob47
« Reply #105 on: October 02, 2023, 06:28:13 pm »
Gents,
Nice Dave much easier with the bigger panels
T888
« Reply #106 on: October 02, 2023, 06:53:39 pm »
Thanks Bob, :-))
I must say I think the smaller the panels the easier to have the door roll.
Regards David
« Reply #107 on: October 02, 2023, 10:49:12 pm »
Yup, a quick tweak and you have a fab rolling shutter! Looks fab already
T888
« Reply #108 on: October 03, 2023, 08:24:12 am »
Thanks Ian  :-))
Regards David
frogman3
« Reply #109 on: October 03, 2023, 11:56:39 am »
YES I ALSO AGGREE Dave THEY look really good better than my idea of the whole door movein but i'll stick to what i know  :-))
chrisb
T888
« Reply #110 on: October 03, 2023, 12:12:52 pm »
Thanks Chris,
As I use to tell the engineers I trained, there’s more than one way to skin the cat  {-)
Regards David
T888
« Reply #111 on: October 14, 2023, 09:55:04 am »
Not a lot being published about the Type 26,  with info limited I’ve spent hours trawling the net for any info.
All that I’ve found is a bit about the Sea Ceptor aft missile system, this is what I’ve built using this info, however as for access doors or ladders fitted on the unit I’ll have to await to see if there is any photos published in the future.
Regards David
frogman3
« Reply #112 on: October 14, 2023, 10:18:15 am »
HI Dave what are these sea Ceptors used for defence of the ship or for offence to destroy a target ? as i know this is still all new stuff
chrisb
T888
« Reply #113 on: October 14, 2023, 10:46:30 am »
Chris,
It’s the New defence system that replaces the Sea Wolf on Type 26 Frigates , Type 45 Destroyers and Will be installed on the new type 26 Frigates
Sea Ceptor  is said to be able to deal with multiple targets at the same time, protecting an area of around 500 square miles over land or sea.
Regards David
frogman3
« Reply #114 on: October 14, 2023, 11:29:26 am »
Chris,
CHEERS Dave for info good luck on your type 26 an i hope you have better luck than i have at the moment
ATB SIR
chrisb
T888
« Reply #115 on: October 16, 2023, 07:00:39 pm »
That’s fine Chris,
Update;
I’ve been running test and checks on Belfast wiring, all ok.
I’ve also started on detailing the hangar roof and plan to install the hangar LEDs.
I’m not too happy with the Sea Ceptor casting so will remove them and cast off new.
Regards David
T888
« Reply #116 on: October 17, 2023, 11:51:55 am »
Update,
Just finished off the Hangar roof detailing and LEDs.
Regards David
frogman3
« Reply #117 on: October 17, 2023, 03:35:08 pm »
Update,
Just finished of the Hangar roof detailing and LEDs.
BRILLIANT WORK Dave can we see it mounted on the hanger an lit up ?
chrisb
T888
« Reply #118 on: October 17, 2023, 04:33:25 pm »
Thanks Chris,
Yes once I’ve detailed the hangar sides internal . :-))
Regards David
philk
« Reply #119 on: October 18, 2023, 09:31:32 am »
excellent work rather jealousphil
T888
« Reply #120 on: October 19, 2023, 08:21:25 am »
Thanks Phillk,
How’s your T45 going?
Regards David
philk
« Reply #121 on: October 19, 2023, 01:01:37 pm »
Thanks Phillk,
hull is with matt beck of becksmodelmarine who is going to give it a coat of fibreglass and smarten it up. Im working on the superstructure at present in between building a large patrol boat and modifying a lesro airboat to ducted fan. Presently working on a working rib bay with launcher and detailing the hanger.phil
T888
« Reply #122 on: October 25, 2023, 05:43:50 am »
Hi Phill,
Sounds like some major work to be done with the T45.
Since my last update I’ve bit the bullet and started on the main mast and bridge section. The mast on the T45 seemed big to me but the T26 are massive.
Any way this does give an advantage by having such a large mast, means installing Radar motors and Nav lights is going to be a breeze.
Regards David
T888
« Reply #123 on: October 26, 2023, 11:37:07 am »
Some photos of the mast and bridge section, now just need to make good any joints that show and wait more info so I can detail it.
Regards David
« Reply #124 on: October 26, 2023, 07:55:49 pm »
Really neat work as always David, steady hands and sharp blades... and ability of course  ;D
Cheers,
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12   Go Up
Page created in 0.189 seconds with 18 queries.
