Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12   Go Down
Author Topic: 1/96 Scale T26 HMS Belfast build  (Read 86600 times)
Rob47
Re: 1/96 Scale T26 HMS Belfast build
« Reply #150 on: February 12, 2024, 08:41:27 am »
Seems it was a tidal issue with PoW not the ship, due out today, fingers crossed
I will finish this model
T888
« Reply #151 on: April 11, 2024, 04:52:12 pm »
Quick Update Gents,
After hours on the net I’ve found some actual build, fitting out photos/info on the Type 26s, so I’m going to start correcting parts of the superstructure I’ve built that was based on early pre production info which has been found to be incorrect.
Two steps forward one step back  <:(
The photos attached is one of the A/C ducting and fire drencher which is fitted in the hanger.
Regards David
T888
« Reply #152 on: April 16, 2024, 05:34:12 pm »
Progress on hanger internals
Regards David
T888
« Reply #153 on: April 30, 2024, 04:42:16 pm »
With the weather looking warmer this week, I’m going to try and see if I paint the hull.
Also correct some of the hanger fittings I messed up.  {:-{
Regards David
frogman3
« Reply #154 on: April 30, 2024, 09:12:58 pm »
hi dave yes hope for warmer wheather an i think your hsngar bay looks great hope you andrea are well
chrisb
T888
« Reply #155 on: May 01, 2024, 05:21:00 am »
Thanks Chris,
Thanks for asking we are both OK hope the same is with you and Jen.
Regards David
frogman3
« Reply #156 on: May 01, 2024, 10:10:49 am »
Thanks Chris,
YES it is Dave
T888
« Reply #157 on: May 04, 2024, 12:41:08 pm »
Had some good weather so took the chance to paint the hull.
I’ve still got to paint the transom which I’ll do once I’ve got the info as to size , shape of the stern trim tab.
Regards David
frogman3
« Reply #158 on: May 06, 2024, 11:41:21 am »
HI Dave she's lookin very good as i like this ship a lot better than the type 45  as yours has a bit more detail on it an yes i know its a steath ship but this one to me looks quite a lot better shape an good to see she's got painted keep it comin on the build sir looks great how big is she ? lenght an beam ?
ATB SIR
chrisb
T888
« Reply #159 on: May 06, 2024, 02:13:30 pm »
Hi Chris
The model size is 61 1/2 inches Beam 9 inches. Very similar to the Arliegh Burke.
The Type 26 has a massive helicopter flight deck and with the mission bay the model has a lot of potential for detailing and working items.
I’ve attached just one of the configuration options.
Regards David
T888
« Reply #160 on: May 10, 2024, 04:28:40 pm »
Restarted wiring all the working functions, just awaiting some 0.5 mm LEDs to arrive from Micro Miniature these will be fitted to the main mast
Regards David
« Reply #161 on: May 11, 2024, 03:56:17 pm »
That is an impressive hangar capacity as the Merlin is no Wasp! It looks like there is sufficient room to work on one without banging elbows etc!
T888
« Reply #162 on: May 12, 2024, 08:40:35 pm »
HI Ian,
Attached is the options that the T26 could be configured for.
Regards David
T888
« Reply #163 on: May 13, 2024, 07:36:50 am »
As apart of the wiring, I needed to mark out the helicopter tie downs, harpoon grid and deck landing lights locations
Regards David
« Reply #164 on: May 13, 2024, 05:24:31 pm »
Blimey I have worked on west end shows with less wiring.....super congratulations  :-))
T888
« Reply #165 on: May 16, 2024, 06:39:22 pm »
Thanks SteamboatPhil
There is more wiring to be added to the looms,  once I’ve confirmed the deck landing light type and locations.
Regards David
T888
« Reply #166 on: May 17, 2024, 08:43:12 am »
Finished off the helicopter tie downs, also cast the bollards from an existing mould.
As for the fairleads I made a new master and moulded, as there is only two for closed fairleads visible on the Type 26 . I've not shown how I made the master closed Fairleads as this method was covered in USS Roosevelt thread.
Regards David
T888
« Reply #167 on: May 24, 2024, 08:56:08 pm »
Hi All,
After a lot of trawling the web for info on the T 26, I’ve found that AGI have got the contract for installing the Visual Helio landing Aid.
The issue I have now is how to install the lighting on my model.
Photo attached is from AGI publication.
Regards David
frogman3
« Reply #168 on: May 26, 2024, 11:13:36 am »
hi dave just been lookin through your build here an i see a sail whinch is that to haul the chopper in an out of the hanger ? looks brilliant build sir
chrisb
T888
« Reply #169 on: May 26, 2024, 11:20:23 am »
Yes Chris the sail winch is used for hauling in/out the helio
Thanks 👍👍
Regards David
T888
« Reply #170 on: June 10, 2024, 10:11:13 am »
Hi Gent
Update but slow and Little progress. Now I've painted the flight deck I can start work on the deck lighting and the best way for the removable section lights can be done.
Regards David
T888
« Reply #171 on: June 19, 2024, 07:07:31 pm »
Another part made and to be fitted.
Regards David
T888
« Reply #172 on: June 22, 2024, 04:36:33 pm »
Next little bits inpro the bridge consoles, which I’ve based on BAE System 3D images.
Regards David
T888
« Reply #173 on: June 24, 2024, 11:30:58 am »
Consoles paint and ready to be fitted
Regards David
T888
« Reply #174 on: July 03, 2024, 02:29:25 pm »
Gents,
Just received these fantastic props from Keith Bender Props (USA) he has excelled yet again.
Regards David
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12   Go Up
Page created in 0.165 seconds with 18 queries.
