Author Topic: Transmister issue ....  (Read 1573 times)
« on: April 22, 2023, 06:46:47 pm »
Via email to mayhem ....
Hi i wonder if anyone can help me i have a model boat and have a problem with my transmitter as soon as i turn on the transmitter
the two propellers start up without even touching the throttle and have no control over props
Thanks for you help Steve
Re: Transmister issue ....
« Reply #1 on: April 22, 2023, 06:56:02 pm »
Do you turn the transmitter on first then the receiver?
« Reply #2 on: April 22, 2023, 06:59:10 pm »
Steve, first thing to check is the trim on the throttle side. Ideally it should be central. Also, you should switch the transmitter on before the boat.
What type of esc are you using in your model?
Edit : sorry Bob, didn't see your reply at first...
NickelBelter
« Reply #3 on: April 23, 2023, 12:32:12 am »
Could be that the transmitter has a failsafe mode for gas engines and it's engaged.  I had this happen to me with my Tx whenever i hit the Disarm switch on the side without realizing.
« Reply #4 on: April 23, 2023, 12:49:14 am »
Steve, Just to clarify - what type/make of transmitter are you using and the other electronics in your boat.
petermun
« Reply #5 on: April 26, 2023, 02:00:02 pm »
One other questioon, have you set up the ESC correctly?
Page created in 0.032 seconds with 17 queries.
