Author Topic: 12" Thomas Tug  (Read 477 times)
JimG
12" Thomas Tug
« on: September 12, 2026, 08:14:23 pm »
Having recently bought a new 3D filament printer after making the usual accessories for it and some stacking Drawers to tidy up my workspace it was time to think about starting a modelling taask. Looking through some old folders containing files I had downloaded from Thingiverse in the past I found a set of STL files for the Model Boats December 2004 free plan for a 12 inch long tug. While the original files were basically for the hull and part of the superstructure I was able to find a later rework with the reast of the parts needed.The hull parts have now been printed are are ready to glue together and the superstructure has been started. I will probably be printing some parts with my resin printer to reduce the amount of finishing needed. A prop shaft is on order and I will be checking if I have a suitable motor spare.
Jim
Dundee Model Boat club
Re: 12" Thomas Tug
« Reply #1 on: September 12, 2026, 09:37:32 pm »
dodgy geezer
Re: 12" Thomas Tug
« Reply #2 on: September 12, 2026, 11:42:24 pm »
Of course there's always the Beaver..
http://eezebilt.uk/Beaver.html
JimG
Re: 12" Thomas Tug
« Reply #3 on: September 15, 2026, 04:10:17 pm »
Well that's the printing completed and the hull glued together. Now for the filling of the joints (good close fits so shouldn't need much work), priming and sanding. I have some Halfords High Build Primer to fill up the faint print lines, printed at 0.15mm line height so these can just be felt. The prop shaft came from Amazon and is 4mm with ball bearings in the shaft tube, the prop is slightly too large for the nozzle but will easily trim to fit.
Jim
Re: 12" Thomas Tug
« Reply #4 on: September 15, 2026, 04:44:37 pm »
Nice Job!
 What glue did you use?
JimG
Re: 12" Thomas Tug
« Reply #5 on: September 15, 2026, 07:13:03 pm »
Loctite super glue, I will probably glass the joints inside the hull but at the moment it feels secure.
Jim
Re: 12" Thomas Tug
« Reply #6 on: September 15, 2026, 08:24:02 pm »
Jim
Re: 12" Thomas Tug
« Reply #7 on: September 16, 2026, 06:16:36 pm »
Re: 12" Thomas Tug
« Reply #8 on: Yesterday at 04:56:11 pm »
 I notice the current model on ThingiVerse has bits missing, upper works etc. .....  {:-{
https://www.thingiverse.com/search?q=thomas+tug&page=1
tica
    • Skalamodelskibe
Re: 12" Thomas Tug
« Reply #9 on: Yesterday at 06:38:35 pm »
Martin check the remix tab of the original
My postings are only reflecting my own opinion and should not be read as the holy grail of truth :-)
JimG
Re: 12" Thomas Tug
« Reply #10 on: Yesterday at 06:59:24 pm »
The remix is at https://www.thingiverse.com/thing:5595043 This has the superstructure , motor mount and battery box.
Jim
Page created in 0.01 seconds with 15 queries.
