Author Topic: Twin motors and RC  (Read 2310 times)
barryfoote
Twin motors and RC
« on: December 02, 2007, 08:21:10 am »
I need a little advise here folks. I have just bought a twin prop 1:32nd scale Tug. it will run on 2 motors and I assume 2 speed controllers. can I have both motors connected to a single stick on the radio or does it have to be more complex. I dont really fancy paying out for the Robbe F14 Navy. Any advise would be most welcome.
Barry
boatmadman
Re: Twin motors and RC
« Reply #1 on: December 02, 2007, 08:39:52 am »
You have a number of options here, you can run both motors through one esc providing the esc is rated at higher than the total current pull of both motors, I have done this with no problem  -  or  -  you can run 2 esc's from one throttle stick using a y lead from the receiver - never done this so not sure how good it is, you may have a little difficulty balancing the esc outputs so that both motors run the same speed.
Then of course there is the 2 esc, 2 motor and 1 mixer option, this runs from one throttle stick and varies the speed of the motors when turning ie, turn to port, port motor slows downrelative to stbd motor and proprtional to rudder swing.
All this can be done with a 2 channel radio set.
Hope this helps
Ian
barryfoote
« Reply #2 on: December 02, 2007, 09:22:33 am »
Cheers Ian.
Barry
FullLeatherJacket
« Reply #3 on: December 02, 2007, 09:25:02 am »
Page created in 0.124 seconds with 17 queries.
