Pages: 1 [2] 3   Go Down
Author Topic: Tito neri build  (Read 32961 times)
Re: Tito neri build
« Reply #25 on: February 05, 2008, 06:28:58 pm »
Have been following the build, very impressive. O0
offshore1987
Re: Tito neri build
« Reply #26 on: February 05, 2008, 07:28:29 pm »
Lookin good Hansen  O0 Have you towed anything with her yet?
Thanks DickyD  :) gettin there at last  :D, just cant wait to try her at the lake when shes finished  :angel:
Hansen
Re: Tito neri build
« Reply #27 on: February 05, 2008, 07:53:40 pm »
No, I did not tow with this tug anything jet, it is just balanced in the tub. There are installed ballast tanks, instead of 10 kilos of lead. It works great.I will go on the lake once it will be finished included superstructure and all details.
Re: Tito neri build
« Reply #28 on: February 05, 2008, 10:17:15 pm »
I have in process this tug too, it is monster power tug.
Ok what are the motors etc
offshore1987
Re: Tito neri build
« Reply #29 on: February 06, 2008, 12:01:23 am »
900 BB motors  O0 running off of 2 12v 12ah batts for me
all the best
Roger in France
Re: Tito neri build
« Reply #30 on: February 06, 2008, 06:32:04 am »
Those 900BB from Graupner are terribly expensive. There must be a good and cheaper alternative?
Similarly, the servos which Graupner offer for the Tito are very expensive. I know that a servo directly shifting a powerful Schotel Drive must stand up to a lot of vibration and be very powerful but again there must be a good alternative?
Roger in France.
Hansen
Re: Tito neri build
« Reply #31 on: February 06, 2008, 02:57:45 pm »
I have in Titio two 900 BB motors.  I thing,for  this tug will be Ok power with two 700/ 12 v motors.
Hansen
Re: Tito neri build
« Reply #32 on: February 06, 2008, 03:15:04 pm »
You are right, servos for Schottle drives are heavy duty servos, with metal gear and BB. I have there not so expensive Hitec 645 BB MG servos, working good. I did not used in my Tito any plywood, I do not like this material for ships, I make new deck and everything exposed to water by fiberglass, 0,8 mm thick. In the hull are installed two ballast tanks, instead  kilos of lead.I make them also from fiberglass. On the bottom of the hull are openings- inlet for water, on the top is vent pipe. Water is 2 cm below waterline, so they are full all time. I am happy with this system, water is everywhere for free, lead is always problem.
dms toucan
Re: Tito neri build
« Reply #33 on: February 06, 2008, 03:17:55 pm »
I bought my 900bb from red bank models for £26 and have fitted them in my new tug Smit Canada
also in Smit mersey a 3111 asd tug
Martin
Hansen
Re: Tito neri build
« Reply #34 on: February 06, 2008, 05:16:55 pm »
What size of Smit Mersey do you have? For so big motors? Alternate motors for Tito Neri and size as this are motors from car ventilators, or best one is from VW Touareg from powered seats. It is 12V MONSTER power BOSCH made motor
offshore1987
Re: Tito neri build
« Reply #35 on: February 06, 2008, 06:52:01 pm »
The other servos you could use in the tito that i have read are good for it is S3305 servos though they are just over £30 each, For my only test at the lake i used 3003 servos which worked but under fullpower and turning they sometimes wouldnt do it so had to back off then let them trun  O0
Im going to stick with the 3003s for now and then upgrade at some point later on
One of the best things i think that would be good for the tito imo would be metal props  ;)
S/S is painted now  O0 but iv run outa glue lol   :(
all the best
funtimefrankie
Re: Tito neri build
« Reply #36 on: February 06, 2008, 07:36:19 pm »
These are what I have on my Schottels, OK so far.
http://www.howesmodels.co.uk/RadioControl/viewProduct.php?ProdID=2914
offshore1987
Re: Tito neri build
« Reply #37 on: February 06, 2008, 07:39:20 pm »
FullTime  O0 they seem ace and with the same out put as the S3305s 9kg  ;)
How would you rate Howsmodels?
all the best
offshore1987
Re: Tito neri build
« Reply #38 on: February 06, 2008, 08:47:30 pm »
Hi, this is how shes lookin atm :) just got to put the grey paint on then its totally painted :)
sorry about the bad pics
all the best
dms toucan
Re: Tito neri build
« Reply #39 on: February 06, 2008, 09:10:20 pm »
Smit Mersey is 1/32nd scale as is Smit Canada I am also doing the line drawings for a Damen 2411 tug I will start the hull this summer
Martin
funtimefrankie
Re: Tito neri build
« Reply #40 on: February 07, 2008, 09:15:14 am »
Allways had good service from Howes.
offshore1987
Re: Tito neri build
« Reply #41 on: February 07, 2008, 07:09:24 pm »
I did some better pics. They was abit rushed but kinda cool :)
offshore1987
Re: Tito neri build
« Reply #42 on: February 07, 2008, 07:10:50 pm »
All the best
offshore1987
Re: Tito neri build
« Reply #43 on: February 08, 2008, 04:27:44 am »
Wooo its late again but got some more done :)
Its not the best job in the world tbh so i might go and redo some bits later on sometime, But got there in the end :)
all the best  O0
Re: Tito neri build
« Reply #44 on: February 08, 2008, 10:37:56 pm »
Looks dammed good to me
Hansen
Re: Tito neri build
« Reply #45 on: February 14, 2008, 07:45:20 am »
Instead of kilos of lead, I have in my Tito Neri water ballast
Hansen
Re: Tito neri build
« Reply #46 on: February 16, 2008, 03:37:18 pm »
Inlets for waterballast on the bottom of the hull
Hansen
Re: Tito neri build
« Reply #47 on: February 16, 2008, 03:40:22 pm »
Deck is fiberglass, not plywood. It is waterproof, not so heavy and very hard. Covers for Schottels will be installed with silicone, not screws are used.
offshore1987
Re: Tito neri build
« Reply #48 on: February 17, 2008, 09:44:12 pm »
Took mine down the lake today first real test sinse its been semi finished, found some problems steerin servos are next to useless so they are going to be changed, and also after about 10 mins the speed controlers seemed to mess up,  just going along then one of them started going backwards and the other fowards   ???  was abit funny gettin it back as it just went around and around lol when pushin the stick faward  :rolleyes: not sure how it did it as they are pluged in with a Y lead so hmm lol anyways once i got it back i turned everything off then back on and it had sorted its self out
also i need to hook the elecs up with a comp thingy to the s/s
oh lol duno how you lot use yours and not nock small bits off   :D
All the best
Re: Tito neri build
« Reply #49 on: February 17, 2008, 10:08:13 pm »
fact of life my friend you build them you break them!!!!!!!!!!!!!!
Pages: 1 [2] 3   Go Up
