Pages: 1 2 3 4 [5] 6 7   Go Down
Author Topic: type 209/1200 Hellenic Navy  (Read 62408 times)
g4yvm
Re: type 209/1200 Hellenic Navy
« Reply #100 on: October 03, 2011, 02:26:53 pm »
Ah, I see!!  No, not quite clever...VERY clever.  Thats what today would be called "thinking outside the box"!
Thanks for the info
D
roedj
« Reply #101 on: October 04, 2011, 07:23:23 am »
Yannis,
Really beautiful work.
A question though - I'm having difficulty understanding your control arm mechanism for the bow planes. I'm working on a Type 202 with similar asymmetrical bow planes so I need a system like yours if not exactly the same. Would it be possible to show a few more pictures of the bow planes in various positions so I can study the relative position of the control arms? Right now, it looks to me that a motion of the control arm running towards the pressure hull will cause both planes to go either in or out at the same time and I know that's not correct. One plane should move in as the other moves out (I think).
Thanks for your time,
Dan
bassplayer1
« Reply #102 on: October 04, 2011, 09:27:57 pm »
David the unbuiltnautilus answer is spot on, I hope it covers your question! Thanks for the nice comment!
Dan, if you watch the video carefully I think you'll find your answer! The secret is the 45 degrees dead  angle that is being produced as the pivot turns! Very simple, very effective and very clever! If you like I'll be more than happy to send you the plans! Thanks for the nice comment!
bassplayer1
« Reply #103 on: October 04, 2011, 09:34:47 pm »
Hi everyone!
Solved the problem with stability and started triming the beast! Also tested all the systems and they work as they should! By the looks of it I'm going to need about another six pounds of lead ballast to bring her on the correct water line! See how it goes! More to come!
roedj
« Reply #104 on: October 04, 2011, 11:29:31 pm »
Yannis,
Thanks. I missed seeing the link to the video. The video shows the mechanism very well - I understand.
Dan
bassplayer1
« Reply #105 on: October 05, 2011, 12:06:10 pm »
Yannis, thats a superb model, and superb modelling!
Couple of questions: in the real one do the periscope suite all go up and down together as per your model or have you taken liberties?  Also, why are the bow planes asymmetric?  Do they counteract torque I wonder?
David
Sorry David, I forgot to answer this part of your question! In the real one the periscopes go up and down in two different groups but that was a bit to much for me so I took liberties! Maybe later on I'll do it properly!
bassplayer1
« Reply #106 on: October 07, 2011, 11:29:14 pm »
Some more trials today and everything works just fine! She stands on the corect water line now and only needs some fine triming wich I'll do on Sunday I hope! Photos and videos attached!!!
http://www.youtube.com/user/bassplayer12100?feature=mhee#p/a/u/0/zrQZh-vxb6E
http://www.youtube.com/user/bassplayer12100?feature=mhee#p/a/u/1/gAiR8lDb5BI
bassplayer1
« Reply #107 on: November 07, 2011, 09:51:35 am »
Some more pictures and a video of the triming stage in a proper pool this time!
http://www.youtube.com/user/bassplayer12100?feature=mhee#p/a/u/0/zqPoWud0aZM
bassplayer1
« Reply #108 on: November 07, 2011, 09:59:58 am »
Also managed to add some details and next thing is to sand the whole boat with fine grade sandpaper(wet) and prepare it for the final coat of paint! More to come!
                Regards from rainy and depressing Corfu!
pugwash
« Reply #109 on: November 08, 2011, 01:31:08 pm »
Hi Yannis - she looks really good in the water and so close to being finished. You will have to start thinking/planning
your next build
Geoff
bassplayer1
« Reply #110 on: November 08, 2011, 08:04:53 pm »
That's right Geoff, I have allready  something on my mind!!! :-)) Thanks for the kind words!
batfish
« Reply #111 on: December 13, 2011, 12:57:29 pm »
Looking Good Yannis,
Any updates???
bassplayer1
« Reply #112 on: December 16, 2011, 12:52:53 am »
Any updates???
Thanks for the kind words!!! As about updates..... {:-{...haven't done much lately apart from almost finishing the scopes and antenas! Being pretty busy at work lately doesn't leave me with enough spare time! Here is some pictures!
bassplayer1
« Reply #113 on: December 24, 2011, 05:56:03 pm »
Merry Cristmas and a Happy New Year full of nice new projects to everyone!!!
                                                       Best regards
        Yannis
bassplayer1
« Reply #114 on: January 10, 2012, 10:37:41 pm »
Finished with the scopes and their mechanism at last! I didn't use the hydraulic mechanism I made earlier because it wouldn't fit after making the new WTC ( I should of known better >:-o) I made a new one with an electric motor and jackscrew and works fine! Here is some pictures and  videos!
http://www.youtube.com/user/bassplayer12100?feature=mhee#p/a/u/2/0A3sdlHC0Gw
http://www.youtube.com/user/bassplayer12100?feature=mhee#p/a/u/0/va522Xuc4GU
pugwash
« Reply #115 on: January 10, 2012, 11:17:51 pm »
Yannis that looks very efficient - but not being any type of engineer i wondered how you kept the
electrics dry.
Geoff
bassplayer1
« Reply #116 on: January 11, 2012, 10:57:54 am »
Geoff as you can see the motor is in its own water tight box and the end switches are of the waterproof type!  The only thing I did it was to waterproof the terminals with silicone sealant! Did a test in the bath tub and everything works fine so far! Hope it stays that way!!!
bassplayer1
« Reply #117 on: January 19, 2012, 05:50:44 pm »
Did some more work adding more details and correcting the hand rail on the sail. Not quite finished yet but here is some pictures!
merriman
« Reply #118 on: January 19, 2012, 07:51:40 pm »
That watertight deck hatch is simply stunning work -- you continue to amaze!
David
Patrick Henry
« Reply #119 on: January 19, 2012, 08:00:13 pm »
Superb Yannis...absolutely superb workmanship.
bassplayer1
« Reply #120 on: January 19, 2012, 10:08:24 pm »
David
Thanks David!!! Much apreciated!!!
bassplayer1
« Reply #121 on: January 19, 2012, 10:10:44 pm »
Thank you very much Rich!!!
Wehrbier
« Reply #122 on: January 21, 2012, 01:57:54 pm »
Hey Yannis,
take this:  :-)) :-)) :-)) :-)) :-)) :-))
regards
Sascha
bassplayer1
« Reply #123 on: January 21, 2012, 03:21:51 pm »
That's very kind of you Sascha!!! Thank you very much!!!
bassplayer1
« Reply #124 on: February 02, 2012, 10:50:06 pm »
Did some corrections on a couple of deck panels and finally painted the boat its final coat! Also sprayed the pennant number and hopefully tommorow I'm going to start doing some weathering!!!
Pages: 1 2 3 4 [5] 6 7   Go Up
Page created in 0.022 seconds with 19 queries.
