Author Topic: Huco straight center section?  (Read 2614 times)
Nige52
« on: November 24, 2010, 11:40:54 am »
I've done a search on the net but can't find anyone who sells these? I have a couple of shafts that I need to glue in perfectly in line with the motor, anyone know?
Nige
barriew
Re: Huco straight center section?
« Reply #1 on: November 24, 2010, 11:47:39 am »
Is this what you are looking for - second item on the page.
http://www.cornwallmodelboats.co.uk/acatalog/couplings-modular.html
Barrie
Nige52
« Reply #2 on: November 24, 2010, 12:06:41 pm »
Hi Barrie,
No it's the red centre section I'm looking for, it's simply to align the drive train up whilst glueing the shaft in. I'm not sure if they even make them, but I have read references on here that say to to use a solid section that the 2 brass ends go in to?
Nige
matphoto
« Reply #3 on: November 24, 2010, 01:10:33 pm »
Hi.
I have used  this http://www.mobilemarinemodels.com/acatalog/Protolign.html
with great success.
Bryan Young
« Reply #4 on: November 24, 2010, 04:29:33 pm »
If you're just trying to line up a couple of shaft ends can't you use a bit of suitable tubing? After all, it's the drive shaft bit you're lining up, so when the outer covering (the bit with the bearings) is set, just withdraw the drive shaft from the tube and all should be nicely aligned. Just a thought. BY.
Notes from a simple seaman
tobyker
« Reply #5 on: November 24, 2010, 10:27:31 pm »
I just use a bit of brass tubing - there's a size in the KS metal centres that's a good fit.
DieselDo
« Reply #6 on: November 24, 2010, 10:48:04 pm »
I agree I use some K&N brass tube cut to the same length as a coupling.
I also cut a small radial angled slot the length of the coupling end to make it easier to fit and remove.
