Pages: 1 2 [3]   Go Down
Author Topic: Prop Shaft coupling seems loose  (Read 17900 times)
Re: Prop Shaft coupling seems loose
« Reply #50 on: May 12, 2012, 10:34:23 am »
Go back to post #15 Jaymac, the photo shows the Hex piece/spline demounted from the shaft and coupling. You need to put a spanner on the small hex which is a locknut and a larger one on the large hex,. In the photo you have shown, hold the spanner on the large hex vertical and pull the spanner on the small one towards you. This should unlock the parts, then you should be able to unscrew the larger one from the shaft. It looks like the brass tube should have been a bit longer.
  Regards  Ian.
 Doh! didn't see page 2 but comments are still valid.
« Reply #51 on: May 12, 2012, 05:08:32 pm »
Hants UK
« Reply #49 on: Today at 12:04:18 AM »
Looking at the image it looks like the coupling end and locknut are right at the end of the thread.
It looks like either the outer shaft has been cut or a longer shaft used.
In all honesty someone has made a right pigs ear of fitting the shaft.
To check it properly the other end needs stripping and then the shaft checking in the tube.
You wouldn't chuckle Bob still I musn't speak ill of the dead
 Any way I've done it and yes the small Hexagon is right at the end of the thread  hopefully all is well  now :-))  Bloody Red screws took be longer to get back in  than the coupling Job and see how accessible they are .its abugger having to use pliers a to hold screws .Serves me right fot chewing my fingernails so much :-) May I once again   thank everyone for their Time patience and input without which I just would have  left as is
« Reply #52 on: May 12, 2012, 05:16:55 pm »
John,
Well done 10 out of 10 for perseverance at least you now know how to do it.
The second is easier till it actually becomes an easy operation.
RAAArtyGunner
« Reply #53 on: May 13, 2012, 01:40:57 am »
Jaymac,
Post a photo of your success  :-)) :-))
« Reply #54 on: May 13, 2012, 09:38:14 am »
Raartygunner jeez thats a mouthful :-) Will do when I get a better  washer fit  soI'l be doing it again  would you like  pics  of things  APART  as well
RAAArtyGunner
« Reply #55 on: May 13, 2012, 09:57:01 am »
Jaymac,
Yes please if possible, have no experience with these couplings.
 Thank you
oldiron
« Reply #56 on: May 13, 2012, 11:03:14 am »
  I would interpret, from this thread, you have had limited experience with things like lock nuts. I thought i should make another suggestion on the grub screw end. It is best to have a flat filed on the shaft that your grub screw is tightening down and registering on. This allows the screw more "bit" on the shaft and resistance to the shaft turning under the screw. I don't know if your motor shaft is like this, but, since you have it all apart it may not hurt to check it out.
« Reply #57 on: May 13, 2012, 12:53:37 pm »
Rar  REe Pics will do
     Correct no experience with these couplins   But lock nuts and  various industry  couplings yes  even the uneversal best couplling   the right size bit of hose pipe and  as many Jubilee clips as needed  kept the plants running many atime with them :-)
 Grub screws I never had to remove the motor end one and there was none at the prop end will bear you point in mind though
tt1
« Reply #58 on: May 13, 2012, 06:54:39 pm »
Think your spot on reaarty. (re spotting the thread on the shaft bit)
« Reply #59 on: May 13, 2012, 08:35:46 pm »
Piece of flexible tube over end of screwdriver, push head of screwdriver into slot on screw head, slide tube over screw head to retain screw.  :-))
« Reply #60 on: May 14, 2012, 07:58:02 pm »
Pics For Raaartygunner
Hi  this shows the motor slid back and the Red sleeve just slid off  the the coupling about tobe unscrewed  Then  the coupling off you can just see    a bit of bare metal twixt thread and brass sleeve  so as said he ran out of thread hence the gap and play. I found a couple of washers that just took up the gap though a bit big they work :-)  then  job done  hope this  of interest to you
« Reply #61 on: May 14, 2012, 08:00:22 pm »
\\ooops another pic needed
« Reply #62 on: May 14, 2012, 08:13:52 pm »
Glad it's all sorted John.
Well done.     :-))
ken
RAAArtyGunner
« Reply #63 on: May 14, 2012, 10:52:15 pm »
John,
Thanks for the photos.
The guys were definitely on the money with the soloution.
Have a similar problem, the outer shaft is short but with a different coupling.
Now know, I need to cut a sleeve for the thrust washer to bear upon and stop the motor shaft moving back and forth.
Thanks again.
Ten out of ten to everyone  :-)) :-)) :-))
« Reply #64 on: May 15, 2012, 12:30:40 am »
Raarty,
The sleeve is a bodge.
The inner shaft should not stick out so far.
RAAArtyGunner
« Reply #65 on: May 15, 2012, 12:45:37 am »
Bob,
If it does, then does the inner shaft need to be cut and re-threaded (or left plain and change the insert), and then the motor moved closer to the shortened shaft.
Alternatively, I suppose you could change the shaft and tube.
oldiron
« Reply #66 on: May 15, 2012, 03:29:06 am »
Bob,
  Change the length of the shaft spacer tube insert. You should have a little bit of thread left over on the shaft after you've tightened the coupling lock nut on. Another danger with having too long a shaft projecting into the coupling is can interfere with the center block on the coupling.
« Reply #67 on: May 15, 2012, 08:26:38 am »
You could just fit a thrust collar around the shaft.
I have used the model aircraft collars that keep the undercarriage wheels on, they are made with a 4mm centre.
This will leave a little of the shaft exposed, but can be useful in tight confines.
Then just lock the coupling end as usual.
RAAArtyGunner
« Reply #68 on: May 15, 2012, 08:48:14 am »
Bob,
Good idea and an easy solution, thank you :-)) :-))
« Reply #69 on: May 15, 2012, 10:30:32 am »
Prop tube should have been longer in Jaymacs application. If you try to move the motor nearer to the existing one to shorten the "Overhung" length of shaft, the body diameter of the motor looks too big to allow it to move much nearer. Strange how many fit the "A" frame supports on the water end of a proptube but omit to add a support dart between the proptube and hull on the drive end of plastic boats. On wooden hulls, there was invariably a bulkhead close to the tube end.
  Regards   Ian.
RAAArtyGunner
« Reply #70 on: May 15, 2012, 01:41:35 pm »
Circlip,
Would fixing a piece of timber across and glued to bottom of the hull, under the shaft provide the required support.
« Reply #71 on: May 15, 2012, 05:12:50 pm »
yes it would.
« Reply #72 on: May 15, 2012, 07:09:18 pm »
Thanks Bob  :-))
  Answered that with out moving my keyboard Raarty  :-)) {-) {-) {-)
   Regards   Ian.
RAAArtyGunner
« Reply #73 on: May 15, 2012, 11:22:47 pm »
Guys,
Thank you.
Modern computer technology is amazing  O0 O0 {-) {-)
Pages: 1 2 [3]   Go Up
Page created in 0.218 seconds with 17 queries.
