Author Topic: Side mounted LED  (Read 6281 times)
cos918
Side mounted LED
« on: June 06, 2012, 03:19:20 pm »
Hello
I am trying to find these LEDs at a better price as I need a fair amount of them
http://www.maplin.co.uk/side-looking-leds-10382.
If you know any suppliers can you post a ink if posible. Have tryed Ebay but can not find them on there.
wartsilaone
  • Ferry Small Ships
  • It was like that when I got here!
    • Ferry Small Ships
Re: Side mounted LED
« Reply #1 on: June 06, 2012, 05:16:31 pm »
Here are some that are a little cheaper John,
http://www.expressmodels.co.uk/acatalog/WHITE_LEDs.html
Ali
ferrysmallships.moonfriut.com
« Reply #2 on: June 06, 2012, 06:21:17 pm »
Try Component shop WWW.component shop.co.uk
cos918
« Reply #3 on: June 06, 2012, 06:54:32 pm »
Hi Ali
Its A bit cheaper thanks.
Hi Dave
tryed them they dont do that type pity as there prices are great but thanks any way.
john
« Reply #4 on: June 06, 2012, 07:23:02 pm »
« Reply #5 on: June 06, 2012, 09:25:05 pm »
Cos918 did u contact them
cos918
« Reply #6 on: June 06, 2012, 11:10:22 pm »
These may help,
   http://www.ebay.co.uk/itm/LED-WHITE-SURFACE-MOUNT-DEVICE-20PCS-PER-LOT-3-2MM-X-2-8MM-/260892542371?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item3cbe6845a3
  Otherwise search for "Surface Mount LEDS" in search bar.
  Regards   Ian.
Hi Ian
thanks for the link but thoes are not the LEDs I am after
john
cos918
« Reply #7 on: June 06, 2012, 11:11:12 pm »
Just looked at there web site
« Reply #8 on: June 06, 2012, 11:22:28 pm »
Get the tel no off the website and give them a ring wont do any harm
justboatonic
« Reply #9 on: June 07, 2012, 09:28:05 pm »
Not sure if this place does side mounted leds but check them out http://www.phenoptix.com/index.php/surface-mount-smd.html
RAAArtyGunner
« Reply #10 on: June 07, 2012, 10:49:17 pm »
For us uninitiated, what is the difference between "standard" and side mounted and now surface mounted LED's as per the last couple of links  {:-{ {:-{
Surface mounted:...................... http://www.phenoptix.com/index.php/surface-mount-smd.html
Side mounted:........................... http://www.maplin.co.uk/side-looking-leds-10382
Also where would you use them on boats.
Thank you
« Reply #11 on: June 08, 2012, 11:15:57 am »
Thank you
Standard - tubular resin thing - domed top, two wires poking out of the blunt end to poke through a PCB and solder to the back, light shines out the dome.  Commonly 5 or 3 mm diameter, but can be odd shapes.
Side mounted - two wires as standard, but arranged so that the light shines out of one side.  Again, various sizes and shapes available.
Surface mount - no wires, just two metal areas that solder direct to the metal on the PCB, the light can shine which ever way that the manufacturer decides.  SMD was intended to aid miniaturizing electronic gear, the LEDs tend to be small.
chingdevil
« Reply #12 on: June 08, 2012, 11:36:54 am »
The led's can be built into bulkhead/deck lights around your model to light up the deck, can also be built into a wheelhouse computor screen I know Umi has done this.
Brian
« Reply #13 on: June 08, 2012, 12:07:14 pm »
Not quite what you are looking for but theses are very good
http://www.dccconcepts.com/index_files/Prewired08mm0603SMTLEDs.htm
The possibilities are endless
I have some of these as well
http://www.dccconcepts.com/index_files/DCC_loco_lamps.htm
thought they might look cool on my CUX 87 as well
RAAArtyGunner
« Reply #14 on: June 08, 2012, 12:57:15 pm »
Malcolm, Thank you, understand what I am looking at now  :-)) :-))
RAAArtyGunner
« Reply #15 on: June 08, 2012, 12:58:14 pm »
Brian
Brian,
Thank you, yes handy items :-)) :-))
SHADOWFLEET
  • 1/200th battleship-39 sunk september 2012
  • thank you for all you help an kind infomation
« Reply #16 on: February 06, 2013, 04:30:38 pm »
Ebay . Ive just got about load of them for pennys an the restistors too with them
The guy i deal with is fair priced an keeps you informed
ships of my fleet in dry dock an builders dock
1/96th scale hms cossack>>building
1/96th scale km Z37 Narvik> refit
1/24th scale Vosper MTB>>building
1/144th USS casablanca Carrier>> shelf
1/96th Hms penalople>> shelf
cos918
« Reply #17 on: February 06, 2013, 05:07:58 pm »
Hi There
I have just done an ebay search using the phrase ( side mounted led ) and there is none. Do you have a link to the seller or a link to a sales page
thanks
john
SHADOWFLEET
« Reply #18 on: February 06, 2013, 05:56:03 pm »
Hi there . Yeah i think i may have got crossed wired here . There no side mounted but should be easy to make . I use to make light units for n gauge union pafic locomotives . And my cousin had n gauge cars with head lights turn on an off . The seller sales micro leds  .his seller name is handsignalman. The leds i had off him are
Really good for value an with the restistors . I call it a bargin
cos918
« Reply #19 on: February 06, 2013, 06:05:27 pm »
Hello
It has to be the side mounted LED as the look life floursent light fittings at 1:100 scale.
Micro leds surface mount leds etc I have no problem getting hold of at good prices. The side mount led are still a bit pricey at 65p each when you buy a lot of them.
john
montessa315
  • I should do it which way?
« Reply #20 on: February 06, 2013, 07:48:46 pm »
If you always do what you've always done, you'll always get what you've always got.
cos918
« Reply #21 on: February 06, 2013, 09:31:20 pm »
Hello
Thank you for the link put they are not the ones.
The led I am after are like in the photo below.
More Coffee
cos918
« Reply #23 on: February 15, 2013, 06:32:27 pm »
Hi
thanks for that. That electroins store looks cheeper at about $.60 wich is about 44p inc vat which ant bad.
certainl beat the rip of britian suppliers.
carlmt
    • Linkspan Models
« Reply #24 on: February 15, 2013, 08:35:49 pm »
Thanks for this info - these look perfect for 1:96 flourescent strip deck lights on the ferries.
Absolutely spot on size!
Will need about 40 for the Free Enterprise V....better get ordering :-))
Carl
Page created in 0.101 seconds with 21 queries.
