Pages: [1] 2 3   Go Down
Author Topic: HMS bold path finder conversion to HMS bold pursuer  (Read 13686 times)
ben hall
« on: January 19, 2011, 11:57:01 am »
this was originals a re-fit for my first navel boat HMS bold pathfinder but some one was selling a mmi that had a plan for her sister ship HMS bold pursuer so it turned in to a conversion which im hoping to be ready for the display i brought it in febuary at midurst annual modellers expedition
ben hall
Re: HMS bold path finder conversion to HMS bold pursuer
« Reply #1 on: January 19, 2011, 12:47:49 pm »
re fit not going well discovered side is made from 1 and a half mm balsa and side snapped
ben hall
« Reply #2 on: January 19, 2011, 12:54:56 pm »
side broke when trying to reinforce half side snaped  :(( so now im putting totaly new sides on
triumphjon
« Reply #3 on: January 19, 2011, 12:59:31 pm »
whats stopping you from building a new hull , using the dimensions from your existing hull but with the inclusion of a vee bottom ?  if you need it drawig first , i can redraw but will need its length , beam and at least a height from the deck to chine rail , have you any idea what the draght was too ?
ben hall
« Reply #4 on: January 19, 2011, 06:30:33 pm »
i had thought about putting a v hull on but i dont know how steep the v is
« Reply #5 on: January 19, 2011, 08:19:44 pm »
Ben,
One of the joys of refurbishing, you never quite know what you will find.
triumphjon
« Reply #6 on: January 19, 2011, 08:38:49 pm »
ben its possible to work that out , and would make a more stable model than the flat bottom its currently wearing ! ive found some dimensions of 121ft  l o a 25ft 6 inch beam with a draght of 6ft10 inches  the vessel also has a round bilge . i would therefore sugest a scale of 1/48th to make it into a managable size ?
ben hall
« Reply #7 on: January 20, 2011, 10:54:31 am »
im not sure what you mean by 1/48 manigeble size :embarrassed: :embarrassed: :embarrassed: :embarrassed:
triumphjon
« Reply #8 on: January 20, 2011, 01:35:45 pm »
at 1/12 th scale your model would be 121inches long ! if you made it at 1/48th scale the finished model would be 30 and a quarter inches long , hence be more managable , given the fact that you often go to the lake on your own , you could carry the model without the need for somebody to take you / collect you again ! hence most of the models i operate are to a size i can safely transport on a bike ! !
ben hall
« Reply #9 on: January 20, 2011, 05:40:01 pm »
youve seen hms bold pathfinder  it 1/48th already isnt it  %% %% %% %% %% :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-):-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-):-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-):-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
triumphjon
« Reply #10 on: January 20, 2011, 09:02:44 pm »
then you need to think about making a new hull for it rather than adding extra weight along a repaired side section ? are you able to follow a half model sized drawing ?
ben hall
« Reply #11 on: January 20, 2011, 10:50:18 pm »
i have got a plan for 1/48th HMS bold pursuer i have hammered quite literally both sides off and am going to plank on frame cross bread with bulkheads and normal layout but the v hull will have plank on frame then an inner del with motor and electronics on and then an upper deck open to the world with details
triumphjon
« Reply #12 on: January 20, 2011, 10:56:27 pm »
having looked at bold pathfinder on the net yesterday she was of round bilge construction so not quite a full vee bottom section , however what are you left with now you have hammered both side from your hull , i should imagine just a few bulkheads , the deck and its flat bottom plank ?
pugwash
« Reply #13 on: January 20, 2011, 11:33:00 pm »
Ben just for your info the Bold boats Pathfinder and Pioneer were both different - Pathfinder as has been said was a round bilge hull
Pioneer had a hard chine hull and they were used for comparison tests prior to the Brave boats being designed. Both were fitted with
Metro-vickers Gas turbines and Pathfinder was originally fitted with two Mercedes Benz diesel engines from a wartime German E boat
but was later fitted with Napier Deltic diesels.
Geoff
triumphjon
« Reply #14 on: January 20, 2011, 11:43:41 pm »
pugwash , do you have any reference to bold pursuer / ive looked on the military powerboat trust but find no mention of her ?  the only vessels ive found reference to are pathfinder and pioneer . jon
pugwash
« Reply #15 on: January 21, 2011, 12:27:00 am »
Jon as far as I can find out there were only two both built by VT and there were no Dark class boats
named pursuer  - only Pursuer was an attack class escort carrier in WWII
Geoff
ben hall
« Reply #16 on: January 21, 2011, 10:44:41 am »
hms bold persuer was the sister ship to hms bold pathfinder they were only test boats with gas turbine engine they could be fitted out as a mtb or mgb
triumphjon
« Reply #17 on: January 21, 2011, 12:50:02 pm »
ben where are you obtaining your information from ?  bold pursuer has no reference under the millitary powerboat trust site ! pathfinders sister ship was pioneer.
deadbeat
« Reply #18 on: January 21, 2011, 12:58:22 pm »
My warships books concur that Bold Pathfinder's sister was Bold Pioneer, these were the only two boats built, there is no record of a Bold Pursuer that I have. My main source is H T Lenton, British Warships dated 1962. By this time Bold Pioneer had already been scrapped, but Bold Pathfinder was still going.
pugwash
« Reply #19 on: January 21, 2011, 01:54:28 pm »
Ben,  Just checked the bible - Janes fighting ships 55/56 edition only the two as listed above - no Pursuer,
Geoff
The long Build
« Reply #20 on: January 21, 2011, 02:08:48 pm »
The ship was never built, I'm Not sure if it was just a Name for one of the design ships which never got built or just a name given to the Plan supplied in the January  2009 MMI mag. based on the 2 built, I did read the article but can not remember what it said..  :-))
ben hall
« Reply #21 on: January 21, 2011, 02:51:49 pm »
i got it from wikipedia i will check the article
ben hall
« Reply #22 on: January 21, 2011, 03:33:20 pm »
it turns out she was her planned but unbuilt sisiter
triumphjon
« Reply #23 on: January 21, 2011, 04:04:17 pm »
so would you like to build as round bilge , or vee hull ?
ben hall
« Reply #24 on: January 21, 2011, 07:07:13 pm »
a round bilge i think would suit her
Pages: [1] 2 3   Go Up
Page created in 0.437 seconds with 19 queries.
