Author Topic: Robbe Flexible Couplings  (Read 3070 times)
ukmike
« on: August 19, 2011, 08:01:22 pm »
Hi.
Has anyone used these ? If so, what are your opinions?.
Thinking of using a pair of these on 815kv brushless out runners.
Here is a library photo.
Mike.
6705russell
Re: Robbe Flexible Couplings
« Reply #1 on: August 19, 2011, 10:18:46 pm »
Personally I think the rubber coupling is far to short and they act more like a solid coupling , best bet is to go for the Mobile Marine Models couplings, far superior...
Russ
barriew
« Reply #2 on: August 20, 2011, 07:43:16 am »
Russ
... or MMBs which are very much like MMM's.
Barrie
« Reply #3 on: August 20, 2011, 08:04:42 am »
ukmike...it really depends on the application  :o
1. the coupling you display is designed to provide a resilience in motion between components in shaft rotation....not necessarily a shaft alignment issue :embarrassed:
2. an example of the coupling design concept......could be to eliminate the impulsive characteristics of an internal combustion engine
For a high power electric application....best copy a typical coupling they use  :-)) .......Derek
unicorn
« Reply #4 on: August 20, 2011, 09:53:09 am »
            Extremely good couplings  --  used them on tugs with 100mm props (in kortz nozzles) and high torque motors
            between 3000 -6000 rpm for many years.
        unicorn
Page created in 0.245 seconds with 17 queries.
