So Simon's been having a bit done on the side!
Scoop ......  are you listening!   You should just about be able to let the cat out of the bag before the start of the season
Simon, the hard bit is when it's just a BIT faster than the one in front, and you have to go round the outside (as you know!)
So if it will now do 50, you're in for an easy life
Phil, never use acrylic on anything in the boat (even the radio box lid) as it cracks at the first hint of vibration!  It would certainly crack if used as an engine mount!  The only stuff of that type you could use is Polycarbonate (Makralon) which will resist cracking but is an absolute bu**er to bond.
If you notice, almost none of the 'glow' boats have stringers because you need a much bigger tank than a petrol, which usually takes up the whole width of the boat.  If your hull is standard polyester, the mounting post method possibly supplemented by an extra thickness of glass under the engine area, will last ages (or until you slam into your first buoy - a large lump of metal decelerating from 50 to nil in less than a foot ......... )
If you go down the 'non wood' stringer route - carbon, on its own, is very brittle and subject to shear fractures.  The best would be a 'sandwich' of carbon (for stiffness) and kevlar (for strength).  You would have to use epoxy resin for layup and use the same resin to bond to the hull.
Good luck with the build.
Danny
(water's going to be FULL of Makara sparkies next year)  ::) ::)
