Author Topic: strip brass  (Read 6304 times)
wicker
strip brass
« on: February 26, 2014, 09:36:48 pm »
anybody know where I can get brass strip about 3mmx0.5 for stantions
longshanks
Re: strip brass
« Reply #1 on: February 26, 2014, 10:54:17 pm »
One source    http://www.squirestools.com/12-19a.pdf
Scroll down to page 19
F1X4 Special Shapes Strip A: 1/64" x B: 1/8"............... £1.95
By my calculations that equates to 0.4 x 3.2mm
Hope this helps
BrianB6
Re: strip brass
« Reply #2 on: February 27, 2014, 06:47:50 am »
Most model shops have K & S brass sections that includes flat bar.
Thicknesses from 1/64" upward and widths 1/16" to 2"
wicker
Re: strip brass
« Reply #3 on: February 27, 2014, 07:43:40 am »
Thanks I will have look around on here as the nearest model shop that is in to boats is 200 miles from me-- thanks again--Charlie
david48
Re: strip brass
« Reply #4 on: February 27, 2014, 08:23:50 am »
Hi wicker
If you look in R&D tugs and working there is a picture of some stanchions I had done at PPD at Lochgilphead . Thy are 3hole stanchions top hole takes a .75 mm wire and the other 2 take a .50 mm wire . Thy have the art work so it could be changed for your job . There is well over a 1000 on a A4sheet.
David
boat captain
Re: strip brass
« Reply #5 on: February 27, 2014, 09:59:53 am »
Hope this helps
That's the strip I use for my flat stanchions.  Really looks the part.
Joe :-)) :-)) :-))
Joe
Liverpool MBC Committee Member
wicker
Re: strip brass
« Reply #6 on: February 27, 2014, 11:10:47 am »
Thanks to all you good lads for your help- Charlie
Paxton
Re: strip brass
« Reply #7 on: February 28, 2014, 10:26:57 am »
I was thinking about material such as this for my stanchions.  What is the most practical method for drilling out the holes for the wire - Pin vice?  That would be onerous for more than 20 or so. :((
boat captain
Re: strip brass
« Reply #8 on: February 28, 2014, 10:43:40 am »
 Make a jig and drill them preferably with a pillar drilling machine.
Joe :-)) :-)) :-))
Joe
wicker
Re: strip brass
« Reply #9 on: February 28, 2014, 06:07:38 pm »
Joe that is just what I was planning to do or get a A4 sheet of etched stantion--Charlie
david48
Re: strip brass
« Reply #10 on: February 28, 2014, 06:15:42 pm »
 Hi wicker.
What size are you wanting I might have some left of my job ,the one's I am using are 14mm 3 hole
David
wicker
Re: strip brass
« Reply #11 on: February 28, 2014, 07:06:53 pm »
I was needing 20mm 3 hole  - -  -  I will make some or go to ppd lochgilphead and try them but they need a computerise drawing
david48
Re: strip brass
« Reply #12 on: February 28, 2014, 08:29:05 pm »
Hi wicker
Have you talked to them I sent a drawing by post and they then did the art work it was all very easy. The reason I sent the drawing by post was I could not get it on the right file format to email them.
David
Paxton
Re: strip brass
« Reply #13 on: February 28, 2014, 08:34:07 pm »
Joe :-)) :-)) :-))
Thanks Joe.  I'll give it a try.
Don
wicker
Re: strip brass
« Reply #14 on: February 28, 2014, 09:02:48 pm »
I spoke to them and they said I would have to supply the drawing but I must recheck the size tomorrow and i will let you know if you size will do  thanks again for your help - Charlie
