Author Topic: Glass cloth  (Read 3907 times)
adamD98
  • Born free, forced to work!
Glass cloth
« on: November 22, 2016, 05:08:18 pm »
Afternoon all, hope your all well.
 I'm just looking for any recommendation for glass cloth/sheet, i.e. suppliers worth looking at. Much appreciate any help or pointers in the right direction.  :-))
Cheers,
-Adam-
Ian K
  • In the workshop, going daft but happy!!
Re: Glass cloth
« Reply #1 on: November 22, 2016, 06:07:45 pm »
Hi Adam,
These people are very good, and kind of on your doorstep!
http://www.ecfibreglasssupplies.co.uk/
Ian
adamD98
Re: Glass cloth
« Reply #2 on: November 22, 2016, 06:54:09 pm »
Thanks Ian  :-)) appreciate that.
 What do you folks generally use weight wise... 48g sounds alright to me but I'm new to using this cloth!
Cheers,
-Adam-
Subculture
    • Dive-in to Model submarines
Re: Glass cloth
« Reply #3 on: November 22, 2016, 07:12:32 pm »
Depends on what you are planning to do with it. There are different weights and different types of woven cloth, and they have their various strengths and weaknesses.
adamD98
Re: Glass cloth
« Reply #4 on: November 22, 2016, 07:18:45 pm »
I have several applications need doing. 1 on the inside of a hull which I just want to strengthen/add thickness too, and the other is a large refurb on the outside of a ply hull...said hull is 16ft long!
Cheers,
-Adam-
Subculture
Re: Glass cloth
« Reply #5 on: November 22, 2016, 07:26:03 pm »
Okay. Such a large hull is beyond my own experience, is this a model boat?  You will need thicker cloth than 48g. Also bear in mind the resin system you use. Epoxy works better with cloth, especially if you will be using many layers as it's a better adhesive than polyester, and thus the risk of delamination between layers is pretty much eliminated. The snag with epoxy is cost and curing, it's much more expensive than polyester, and you need a warm environment for it it to cure well.
You could also consider chopped strand matt with glass tissue on top to smooth out the finish. This works best with polyester resin, and will be fairly inexpensive.
adamD98
Re: Glass cloth
« Reply #6 on: November 22, 2016, 07:31:45 pm »
It most certainly is a model. It is the Type 45 destroyer at 1/32nd. It needs a good refurb and waterproofing before it sails again unfortunately!
Cheers,
-Adam-
Subculture
Re: Glass cloth
« Reply #7 on: November 22, 2016, 08:05:49 pm »
Is the hull made of wood?
adamD98
Re: Glass cloth
« Reply #8 on: November 22, 2016, 08:42:24 pm »
Certainly is
Cheers,
-Adam-
Subculture
Re: Glass cloth
« Reply #9 on: November 22, 2016, 08:49:51 pm »
Okay, so a layer of glass cloth on the inside, and one on the outside would add enormous strength and totally waterproof the hull. You shouldn't need to go thick, as the wood acts as a sandwich, and thus you get a very strong composite. Something like 8-10oz cloth should be adequate, and i would be enclined to go for a twill weave, as it drapes well.
adamD98
Re: Glass cloth
« Reply #10 on: November 22, 2016, 08:52:52 pm »
Very much appreciate that advice, it is certainly taken on board and I will let you all know how I get on! It's a fairly big project and I have to remove the existing paint first!
Cheers,
-Adam-
captain bligh
  • Boats oh'd av um
Re: Glass cloth
« Reply #11 on: November 22, 2016, 08:56:57 pm »
Hi Adam
If you give the plywood a coat of accelerator first if your using polyester resin will help it stick a lot better :-))
It's not a bad man who makes a mistake its a good man who can get over it.
adamD98
Re: Glass cloth
« Reply #12 on: November 22, 2016, 09:06:39 pm »
Many thanks for the tip Mike, much appreciate it.
Cheers,
-Adam-
Arrow5
Re: Glass cloth
« Reply #13 on: November 22, 2016, 09:15:28 pm »
 Application of polyester resin and chopped strand glass is a quicker way if you can find a friendly contractor that uses the chopper-gun technique, septic tank maker for example or roofing panel maker. Then an application of finish gel-coat to give smooth surface in correct R N colour. I would only use resin on the inside without glass.
..well can you land on this?
Re: Glass cloth
« Reply #14 on: November 22, 2016, 09:24:57 pm »
Just hope the engine is up to spec, don't want to have to lay it up if you under spec it - seems all 45's are problematic in this regards  {-) {-) {-) {-) - just joking.
adamD98
Re: Glass cloth
« Reply #15 on: November 22, 2016, 09:37:26 pm »
Thanks chaps, again the advice is much appreciated. I have plenty of paint, light weather works grey to be exact which is the paint I use on all my RN warships.
  :embarrassed: {-) Yes fortunately this is the only T45 without power issues, perhaps she and Duncan's carrier can be called upon to fire water balloons at the encroaching enemy ... it's about the only defence we have left!
Cheers,
-Adam-
