Pages: 1 2 3 4 5 6 7 [8]   Go Down
Author Topic: What I've been up to  (Read 42835 times)
Nordlys
Re: What I've been up to
« Reply #175 on: October 25, 2022, 08:25:33 am »
They all look in good shape even before you start refurb work Andy.
Have you not had any issues lifting them about ie into car and from car to bench?
Usually listed as heavy otherwise I'd like to work on project like this as a change.
They end up looking brand new! Really worthwhile.
N
Taranis
  • Balne Moor MBC
« Reply #176 on: October 25, 2022, 08:37:10 am »
They are all sub 25kg and they are not in good shape internally which is why they fell into disuse. Users were lazy and often lost or misplaced the correct tools then resorted to violence  {-)
All of my now many blogs are on
https://ukengineforum.forumotion.com/
One example
https://ukengineforum.forumotion.com/t10981-lister-h1-restoration
ANDY
Nordlys
« Reply #177 on: October 25, 2022, 01:40:41 pm »
Hmm, those links shed a rather different light on condition and clearly show the extent of your refurbishment work, far more than I expected to see.
25kg still a good lift for me.
N
Taranis
  • Balne Moor MBC
« Reply #178 on: November 09, 2022, 08:46:59 pm »
My current project the 1938 Lister pump set is providing challenges.
The Magneto a Lucas RS1 has a top cover cap of Bakelite that has seen better days and the contact screw thread is badly damaged from previous poor attempts to remove the steel screw (bad design)
I appealed for a second hand replacement but that met a stone wall.
So left with no alternative but to have a go at a fix I did!
I cleaned the fixed part up enough to apply solder flux
Then tinned the contact face and a 4 mm brass nut before positioning for soldering together.
With the aid of a chopped down motor coupling I could put a 4mm brass screw in the lathe
To produce a contact screw how it ought to be
Penetrates right thought the HT lead and secures it in place.
Final clean up and all the many cracks in the 84 year old Bakelite were treated to Zap-a-Gap CA
I'm hoping the magneto coil and capacitor are still working
ANDY
Taranis
  • Balne Moor MBC
« Reply #179 on: November 09, 2022, 08:56:59 pm »
The cast iron base was stripped and primed. The consensus is that it was most likely satin black originally
Having salvaged what was usable from the trolley I rebuilt it with better axles and smaller wheels. It was also too narrow so this was altered too. I wanted the trolley to look more like a concrete plinth as this would never have been a mobile unit.
Day 1 reminder
ANDY
Taranis
  • Balne Moor MBC
« Reply #180 on: November 29, 2022, 08:35:23 am »
Winter project won't last to the new year. Nearly ready to start on the pump which is mainly a cosmetic strip service and paint.
I got more info about my engine
Lister D No 148091 was supplied to Gibson Bros of Melling Lancs. on 17-5-1939
ANDY
« Reply #181 on: November 29, 2022, 08:41:58 am »
Wow! Very, very impressive Andy. You've got it looking like it would from brand new... Great work  :-))
Taranis
  • Balne Moor MBC
« Reply #182 on: November 29, 2022, 08:51:21 am »
Thank you Ray
This hobby is no different to model boats in terms of the different types of people LOL rivet counters and purists thrive.
Manufacturers cut many corners to save every penny so most restorers of my type produce an engine better than it ever was and just like boats you never can get back what you invest but the pleasure is in the journey.
ANDY
Nordlys
« Reply #183 on: December 12, 2022, 12:21:31 pm »
Are there any common problems you find when refurbishing?
Can you obtain parts easy enough?
N
Taranis
  • Balne Moor MBC
« Reply #184 on: December 12, 2022, 12:59:19 pm »
That's very much like how long is a piece of string.
Rust and seized threads are common as well as wear. It all depends on the condition to begin with and its past life..
Rare engines will all suffer hard to find parts.
A Lister D type was probably the most successful engine in history produced over many decades so there are parts around even if taken from another incomplete engine.
For all engines the expensive parts are Magneto/ Carburettor/ Fuel tank/ Starting handle/ exhaust & muffler.
People buy engines just to harvest the parts and turn £100 into £300 for the bits. There's good and bad to that, the loser is the donor engine but the winner could be 2 or 3 running engines.
This 1938 will be running this week, I'm now working on the water pump it drives
ANDY
Taranis
  • Balne Moor MBC
« Reply #185 on: December 12, 2022, 01:07:47 pm »
Last week I made a new trolley for the Petter in the background. I sold the old one for £50 which went a long way towards making the new.
That now weighs 120kg complete. 16kg is the trolley.
ANDY
Nordlys
« Reply #186 on: December 12, 2022, 04:24:08 pm »
That's some weight to manoeuvre? On wheels only I guess.
Nice work, all of them. Just the weight that worries me about getting involved.
Your photos are very tempting!
Thanks.
« Reply #187 on: December 12, 2022, 04:38:17 pm »
Taranis, are you familiar with the Amberley Museum in Sussex, thay have a good collection of old domestic engines.
https://www.amberleymuseum.co.uk/explore/explore-industry/stationary-steam-engines/
It is just 45 minute drive from us and I have visted several times, probably overdue for another after it reopens next month after the winter break although I'll probably wait for the Spring. A fascinating collection of exhibits in a beautiful setting.
Taranis
  • Balne Moor MBC
« Reply #188 on: December 12, 2022, 04:41:43 pm »
Thanks no but I wouldn’t use fuel to go see static engines. I’m only interested in outdoor crank up meets that are not too far
ANDY
Taranis
  • Balne Moor MBC
« Reply #189 on: December 12, 2022, 07:13:44 pm »
Thanks.
There is something to suit everyone
ANDY
nemesis
« Reply #190 on: December 13, 2022, 11:03:00 am »
Hi Andy, Certainly some love been expended on these engines, lovely. Tell me Andy, when is the shed extension coming??. Bill
Taranis
  • Balne Moor MBC
« Reply #191 on: December 13, 2022, 12:08:09 pm »
I’ve plenty if room for another year yet Bill thanks  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #192 on: December 28, 2022, 10:15:45 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #193 on: December 28, 2022, 10:19:03 pm »
Nearly done just waiting for a nice day to crank it up
My proxxon lathe was near the limit making a new cross shaft for the pump
ANDY
« Reply #194 on: December 28, 2022, 10:36:25 pm »
Looking Good!
 .... the gear looks a good finger mangler!   %)
nemesis
« Reply #195 on: December 29, 2022, 02:14:55 pm »
Hi Andy, Nice to have that job satisfaction at the end of a recon/rebuild.Absolutely great. bill
Taranis
  • Balne Moor MBC
« Reply #196 on: December 31, 2022, 12:51:01 pm »
Looking Good!
I wonder if guards came first or mangled fingers 🤔
ANDY
Taranis
  • Balne Moor MBC
« Reply #197 on: December 31, 2022, 12:54:11 pm »
Cheers Bill
I bought 5 litres of E5 yesterday £8.50  %%   and got the plumbing done today. Wednesday looks favourite for Youtube
Happy New year to everyone
ANDY
Pages: 1 2 3 4 5 6 7 [8]   Go Up
Page created in 0.051 seconds with 18 queries.
