Pages: [1] 2 3   Go Down
Author Topic: How to do hull plating please?  (Read 16154 times)
Edmund
« on: January 28, 2009, 11:11:37 am »
Hello, Anyone please tell me how to do hull plating ? would the plates lap over at the edges , like in - out - in - out? (like Titanic for eg), or would they butt up edge to edge? Looks like they have something between them horizontally on the pics . Hmm {:-{
thanks , Ed. :-))
BarryM
Re: How to do hull plating please?
« Reply #1 on: January 28, 2009, 12:09:12 pm »
Ed,
"It all depends" is the answer. There are several systems of plating depending on ship type with 'all flush' being the most expensive. I will dig out my old books and put up a few pics.
Barry M
« Reply #2 on: January 28, 2009, 12:29:54 pm »
Here are just a few links to some builds and some questions regarding hull plating.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=14370.0
http://www.modelboatmayhem.co.uk/forum/index.php?topic=13888.0
http://www.modelboatmayhem.co.uk/forum/index.php?topic=2165.0
http://www.modelboatmayhem.co.uk/forum/index.php?topic=4715.0
If you go to the main page and do a search you will find more.
I hope this gives you a start.
nhp651
« Reply #3 on: January 28, 2009, 12:35:27 pm »
diagrams taken from Nicholsons seamanship and nautical knowledge 1554 vintage. hope they help.
BarryM
« Reply #4 on: January 28, 2009, 12:50:50 pm »
Eh? - 1554 vintage? You must have been an apprentice to Noah!  O0
Mine are only 1942 vintage.
BarryM
« Reply #5 on: January 28, 2009, 01:11:25 pm »
Next
BarryM
« Reply #6 on: January 28, 2009, 01:12:03 pm »
and last
nhp651
« Reply #7 on: January 28, 2009, 03:36:12 pm »
slip o' the finger, barrie.
must take more tonic with it, and the sun wasn't even over the yard arm either,lol {-) {-) {-) {-) :embarrassed: :embarrassed: :embarrassed: :embarrassed:
Edmund
« Reply #8 on: January 28, 2009, 04:50:23 pm »
 :-)) Thanks for the links and all the diagrams, just the job, the one re applying to plug esp , as this is what I will be doing. Right ah's off to peruse some diagrams :}
Oh trying to build something like this, so @ 1/48th probly don't matter much anyway  {:-{
ta,
Ed.  :-))
 {-) butt straps
Edmund
« Reply #9 on: February 27, 2009, 01:11:31 am »
Hello again  :-)
So on ere where the armour plates join , it looks like there are squares covering the butt joints? does that sound right ? They wouldn't be joggled or owt fancy like that ?
thanks, Ed.
BarryM
« Reply #10 on: February 27, 2009, 09:04:53 am »
Looks like an external butt strap.
Barry M
Edmund
« Reply #11 on: February 27, 2009, 11:15:00 am »
Oh aye it does, almost exactly like the first diagram , must ave missed that  :embarrassed:
So it just claggs on top over the joint then.  :}
good, thanks.
Ed.
maninthestreet
« Reply #12 on: February 27, 2009, 03:57:06 pm »
Barry M
Is that some of sex toy??  {-) {-)
Edmund
« Reply #13 on: February 28, 2009, 01:44:35 pm »
Just out of interest , how big is the head of a rivet , I suppose that is like asking how big is a screw?  %%
Ed.
BarryM
« Reply #14 on: February 28, 2009, 02:18:25 pm »
When flattened while hot, the head of a rivet is required to be 2.5 x the shank diameter without cracking at the edges.
Cheers,
Barry M
Umi_Ryuzuki
« Reply #15 on: February 28, 2009, 05:51:08 pm »
Heres a run at it by Pat Matthews
post #147
http://www.rcgroups.com/forums/showthread.php?t=775147&page=10
Edmund
« Reply #16 on: March 01, 2009, 10:00:45 pm »
What I really meant was what is the actual physical dimension of the rivet head ?  so if it is a 1" diam rhe head will be 2.5".  Is that like a Titanic sized rivet ? Would big uns like these be used fer an Insect ? I'm trying to figure out how big they would need to be on a 1/48th scale model.  :-)) Pretty small I'm guessing. {:-{
ta.
Ed.
ian kennedy
« Reply #17 on: March 01, 2009, 10:07:49 pm »
Hi Ed,
As an educated guess at 1/48th scale i would suggest a dome head rivet would be about 0.50mm diam, maybe as large as 0.75mm.
Edmund
« Reply #18 on: March 01, 2009, 10:13:28 pm »
 :-)) Thanks Ian, um I better find that jeweller's eyepiece then  {-) Ed.
Hmm well I make that um 1.5mm x 48 comes to 72mm  <:( which is way too big. damn  >:-o
Umi_Ryuzuki
« Reply #19 on: March 02, 2009, 12:33:33 am »
A little more on plating,
http://www.rcgroups.com/forums/showpost.php?p=8805900&postcount=169
and rivets.
http://www.starwoodmodels.com/products/ssm/rivetkit.php
I did rivets on a friends armor model using super thick CA glue.
It is very difficult to stay consistent.
ian kennedy
« Reply #20 on: March 02, 2009, 10:16:08 am »
Hi Ed,
I meant that the finished rivet head would be 0.50-0.75mm diam at 1/48th, i think you may have mistakenly multiplied this by 2.5 and that is why it may seem too large.
A 0.50mm dia head x 48 would give a domed rivet head of 24mm dia, this is quite small so i would suggest 0.75mm dia for heads which scaled would give you a 36mm dia rivet head. :-))
I always look at photographs with crew about the decks this is for a comparison between all fittings/fixtures to gauge, height, width and perspective this is a must when spotting sizes for such things as bolt heads and rivets, which are not allways high lighted on builders drawings.
Good luck and i hope this has cleared up the confusion?
Edmund
« Reply #21 on: March 02, 2009, 10:44:16 am »
Thanks fer the links there Umi :-))
Oh sorry Ian  I  was referring to a sewing pin which is about 1.5mm / 1/16th head size which makes it about 2 1/2" fer a 1" rivet in the real world which is way too big that would be nearer 1/24th scale ?
I will have to have  a ponder whether they will be really noticeable anyway at 1/48th  {:-{
thanks ,
Ed.
BarryM
« Reply #22 on: March 02, 2009, 10:48:32 am »
Just say it's a flush-riveted hull.  %)
ian kennedy
« Reply #23 on: March 02, 2009, 10:58:11 am »
Hi Ed,
The rivets would be as prominent as the butt strap image you posted, so it is really your choice if it were me then i would show them.
Two methods of doing this are,
1, when making the plates out of litho plate emboss the back edges of them with the rivet patterns and glue into place.
2, using a fine needle syringe filled with a slow setting adhesive, either PVA or a very slow cure epoxy dab the needle tip along the pre marked lines on your plating and leave to set overnight. If you mess up these, just wipe off and have another go.
« Reply #24 on: March 02, 2009, 11:13:51 am »
Hi all
Have a look at the picture - If we look at the size of the holes that have bean drilled in the deck beam this will give us some indication of the size of rivets
this may help
bluebird
Pages: [1] 2 3   Go Up
