Pages: 1 2 3 4 [5]   Go Down
Author Topic: air boat fast build  (Read 37804 times)
tica
Re: air boat fast build
« Reply #100 on: May 06, 2011, 08:03:47 pm »
Looks nice, would be good to see a video..
Would like to do a video but at this moment in life i choose not to spend money on that kinda toys (I'm unemployed at time)
LarryW
« Reply #101 on: May 06, 2011, 08:48:07 pm »
     HI ALL ,NICE TO SEE  every body having a go at air boat but its now moving away from the glynn guest design with is pretty quick .
 and simple lay out , that works for me , and it does what says on the tin , i am working on the proping with mine, .....LARRY W...
triumphjon
« Reply #102 on: May 06, 2011, 10:29:56 pm »
has anybody else had any problems with water over the bows when running ?
Patrick Henry
« Reply #103 on: May 06, 2011, 10:32:22 pm »
I'll let you know tomorrow, hope to get mine wet for the first time.
triumphjon
« Reply #104 on: May 07, 2011, 07:36:46 am »
hope the weather improves , weve been lashed with thunder / lightening & heavy rain since about half ten last night ! work permitting i was hoping to get a sail today myself as ive altered the bow section !
Patrick Henry
« Reply #105 on: May 07, 2011, 07:46:18 am »
We had a shower early on, a couple of rumbles of thunder around 0400hrs, but now it's as black as yer 'at out there, not looking good!
Good luck with your weather!!
Patrick Henry
« Reply #106 on: May 12, 2011, 08:35:52 am »
How we all doing with these airboats? Still not run mine yet, every time we get a calm day it rains...we get a dry day and the wind blows half a gale. I've changed the radio from the supplied 27Mhz AM set with that horrible pistol grip tx to a 40Mhz conventional radio, much more comfortable to hold, and fitted an Mtroniks Viper esc, with reverse function.
It also has a pilot fitted, affectionately known as 'JD', aka Jack Daniels. Not too sure about the tattoos though...
triumphjon
« Reply #107 on: May 12, 2011, 08:45:34 pm »
having fitted an inch extension to the bows , its slightly better but still ships some water ,  its also badly affected by cross winds but im operating in an area of open sea water !  airboat two is under construction , being made from yellow insulation foam coated with polyester resin , which when completed should be unsinkable ? ?
Patrick Henry
« Reply #108 on: May 12, 2011, 09:12:45 pm »
I've seen airboats made from foam before...brilliant idea, and as you say...totally unsinkable.
Good luck!
triumphjon
« Reply #109 on: May 13, 2011, 07:15:11 am »
when it looks more like a boat i will post some pictures ,  its intended for our 14 year old grandson to operate , he used mine last week , kids only seem to know flat out speed even when there is a stone wall in its path !
The long Build
« Reply #110 on: May 15, 2011, 09:33:58 pm »
Well a few more modifications, as in The hull is now the correct width !! to the plans, Was amazing on how much better it performed on the water..  Just need to widen the cage and then it is ready for the group race.. Also had to dismiss Captain PostMan Pat as he just caused to much wind resistance, now under the command of Captain Scooby..
Oh yes and a better paint job..
The long Build
« Reply #111 on: May 22, 2011, 07:32:40 pm »
Well after the straight running competition with my STEAM boat and 14 points, I took out Scooby 1.  I assume that the captain Scooby knew something I did not as I managed to flip the boat twice ! (was a tad Windy) however the inside of the boat stayed dry and after letting the access water drain off the decks it was off again..
What I had not thought of at the time when upside down was if I had applied throttle would the prop have turned ?.
Oh and its amazing where all the Camera's appear from  <*<  hope to get a shot of it in turtle mode..
triumphjon
« Reply #112 on: May 22, 2011, 07:45:19 pm »
i dont get much of a problem of the boat flipping , but have a constant battle with water over the deck , & nose diving into waves ! , hopefully the mk2 will be a drier model !
The long Build
« Reply #113 on: May 22, 2011, 08:50:11 pm »
Pop by our lake on a windy day, will get it flipped for you  :} :}
triumphjon
« Reply #114 on: May 23, 2011, 08:16:41 am »
i get my own share of wind thanks , yesterday gusting at around 30 mph !  ive increased the height of the hatch coaming to 1/2 inch high on my mk1 see what happens later ,
this is my mk1 , the mk2 is still on the bench , with its ski jump style nose has become 10 mm longer , but remained at 200 mm beam , ive made it around a foam core which ive then coated in polyester resin and glass matting , as ive found the mk 1 slides better for it ! power is to be another 400 brushed motor does anybody have any recomendations as to a better variant ? this model ive placed the motor pylon onto a 1/8 ply panel which is removable from the hull , the underside of this has the rudder servo , the esc and an rx
tr7v8
« Reply #115 on: May 23, 2011, 01:33:55 pm »
In the past I've built quite a few of these generally IC but a few with electric. I'd make a couple of comments.
1. Torque reaction can be a problem you need a beam of around 1/3rd or greater than the length. my Lesro airboat would torque roll with a 35 on it if you bashed the throttle open. Opened slowly it was very quick.
2. Tractor is a better design (prop first then motor), pushers limit your prop choices & are more expensive.
3. You need an adjustable thrust line as this & C of G are critical & you generally need downthrust to get a decent trim.
4. Raking the rudder hinge line like an aeroplane helps keep the bows up in turns & encourages the correct lean.
Jim
triumphjon
« Reply #116 on: May 23, 2011, 07:00:38 pm »
the mk1 has a slim packer under the motor pylon which has allowed the motor to have a very slight upward angle to it , should i not have this ?   im currently using a 6x3 prop without a gearbox .
tr7v8
« Reply #117 on: May 25, 2011, 08:43:36 pm »
Nope you need downthrust to lift the bows not up thrust. Draw a vector diagram & it will show it.
Jim
triumphjon
« Reply #118 on: May 25, 2011, 08:55:46 pm »
sorry not heard of vector diagram ? as the packer is under the leading edge of the  pylon do i need it at the trailing edge instead ? it does have a tendency to try and bury the bows under the surface if i hit a wave !
tr7v8
« Reply #119 on: May 26, 2011, 08:19:21 pm »
Draw a side view, draw a line forward through the thrust line, motor shaft, the bottom of the hull (Waterline) has a line drawn pointing backwards. So the thrust line is above the waterline wanting to rotate the whole lot bows first into the water. Tilting the thrust line down towards the waterline lifts the bows. You'll only need 3-6 degrees or so.
Jim
triumphjon
« Reply #120 on: May 26, 2011, 09:21:24 pm »
thank you TR 8 ! it sounds like i need to angle my motor the oposite direction ?  do i take it tr7 v8 refers to your variant of the marque ? mines a 2500 saloon !
tr7v8
« Reply #121 on: May 31, 2011, 09:50:00 am »
Errr Yes & Yes. I had a TR7V8 for 7 years, had it completely rebuilt by Robsport at vast cost & then decided I'd fallen out of love with it & sold it. Now into Porsches with a 944. Pics of the 7 are here:-
http://www.pbase.com/tr7v8/rover_v8
Jim
triumphjon
« Reply #122 on: May 31, 2011, 09:59:52 pm »
ive tried three tr7s , the first, a fch auto was sold on after i was unable to get it running ( since found out why , jackshaft pin sheared )  second was v8 dhc wich was an accident damaged car which we used the axles & suspension for the first car , shell sold to robsport ! the third another fhc was last know to be living in malvern ! ive decided to stick with the big saloons , currently owning an early mk2 2500 tc .air boat was better with its reangled motor , mk 2 is now being tested
Patrick Henry
« Reply #123 on: July 10, 2011, 09:04:25 am »
I've completely refitted my Alligator airboat, it now has a Planet5 2.4gHz radio, runs on a 11.1v lipo batteries, and has a 3 LED Ultra Brite flashing red light fitted.
Pages: 1 2 3 4 [5]   Go Up
