Author Topic: 1/12 Severn. Hull stregthening???  (Read 3402 times)
lesfac
  • Never too late for a happy childhood
« on: February 03, 2016, 09:59:39 am »
Has anyone strengthened the hull?
I was wondering about bonding some timber under the lip of the hull top opening. Also the bottom of the hull is a large area. My other boat can sound a bit like a drum at speed as the water smacks the hull.
Good idea or waste of time?
Les
nemesis
Re: 1/12 Severn. Hull stregthening???
« Reply #1 on: February 03, 2016, 01:25:49 pm »
Hi, My opinion...Waste of time and material. Nemesis
Flundle (Speedline Models)
« Reply #2 on: February 03, 2016, 02:12:06 pm »
Well.....might be worth it under the deck alongside the opening because I have picked up hulls like that and cracked them as a result. Otherwise, no need.
lesfac
« Reply #3 on: February 03, 2016, 03:33:17 pm »
Thanks Adrian
My inclination is to sometimes grab it on the edge of the opening and its going to get heavier as bits are added. The mishap you describe is what occurred to me.
I think it would be a good move for me. Just so long as it doesn't cause any build problems down the line.
Les
Robin smith
« Reply #4 on: February 03, 2016, 11:16:08 pm »
When I built my Severn I put a ply base in to mount components on a full length opening vertical wall either side out of ply. This made it more rigid but also provide opportunity to mount electrical items and batteries etc allowing excellent access to motors etc
« Reply #5 on: February 04, 2016, 11:12:46 am »
Les,
Robin is spot on with that suggestion. Depending on what you, do there could be a lot of wiring about and Robins method is very tidy.
The additional weight on the model is not an issue in terms of waterline and with emax of turnigy 40-45's on four cells you are never going to notice anyway!!
Adrian
lesfac
« Reply #6 on: February 04, 2016, 11:36:29 am »
I was wondering if any weight issues would arise so your post has answered that question. Thanks Adrian.
Robin, would you have any photos of what you describe?
Les
Page created in 0.014 seconds with 17 queries.
