Evening All
Thanks Paul and Derek, very kind words.
I did get some time on the water earlier, generally very pleased with how the boat looks and runs out on the water. Sunlight really makes the mahogany, varnish and chrome come alive.
I did make a change to the gearing, as a trial I've just reversed the pulleys, so it's now 2:3, so prop shafts are spinning faster than the motors. So its quite noticeably quicker, wthout needing full motor speed. And still only drawing 10 to 12 A on each motor at a very satisfactory scale full speed. The motors are overpowered for the boat I think, but the upside is not needing to make them max out. And so they are noticeably quieter. That was always an aim. I've also added neoprene foam at the back of the bench seat to avoid motor sounds escaping the hull. All together the motor sounds are being contained well. At speed the loudest noise is the water being pushed away from the hull.
The hull rides very well and water is thrown out and down. I strongly recommend either the chine mod that I built in, or a similar approach. The cockpit remains dry. Water comes off the chine and separates from the hull cleanly. Handling from the rudders is good, differential steering on shafts only works well too. I didn't experiment today with reduced power to the inner shaft when turning at speed, but I will.
Driver and passenger stayed in place nicely just using magnets, the hull slices through chop with no drama.
I'm seeing about 30m of mixed throttle runtime on the 3000mwh LiPos. I think that's a reasonable balance.
I'm a bit concerned that the ESCs are still running a bit hot. Had a reading of 70c... I've already added a fan, but suspect my sealing of the hull to keep sounds down is having the unwanted effect of keeping the heat in too... So next is to add a water cooled heatsink to the aluminium box that houses the ESCs. That should keep them cooler...
Slight list to port, on reflection the gyro is set to port, as is the receiver the water pump, plus the chromed brass steering wheel. Maybe together they're enough to offset the hull. It's only visible to the critical eye at rest... I'm thinking to move Maybe one of the lipos, or just add some lead. We'll see.
Now able to just enjoy running the boat which is great and what other all been about after all. 2.5 years to get to this point...
Once cooling is nailed, the skier is the next task...
Very best regards to all.
David.
