Pages: 1 [2] 3 4 5   Go Down
Author Topic: air boat fast build  (Read 36815 times)
Dekan
tobyker
Re: air boat fast build
« Reply #26 on: February 02, 2011, 10:05:49 pm »
Lots of photos of the real thing at Canadianairboats.com. You don't need a step, but to make them turn properly you need hard chine forrard, round bilge aft. See canadianairboats gallery.
Dekan
« Reply #27 on: February 04, 2011, 05:16:10 pm »
Nope!
an "airscrew" (lets get pedantic :-)))  and in our case a fixed pitch Airscrew is designed to work in one particular direction of rotation only, the surfaces of each blade are curved and if you were to take a cross section through a blade it is usually an airfoil section just like a plane's wing (thicker near the leading edge, thinning to nowt at the trailing edge of the blade) so it produces the maximum amount of thrust as it screws through the air, like a wing produces lift.  if you run it in the wrong direction of rotation it will produce thrust (because it has a pitch) but it will be very inefficient.
now
lets look at an I.C. powered plane, engine facing forwards, prop at the front, a "normal" tractor prop is required say it runs anti clock.
that I.C. engine will only run in one direction of rotation (anti clockwise) so if you put it in a pushing configuration the tractor prop will be running backwards.. very inefficient  so you need a "pusher" prop designed to run backwards
in the case of our electric airboats we can reverse the rotation of the electric motor by swapping the supply leads  +/- over and it will run either clock or anti-clock rotation no problem   so if the motor shaft is facing forward use a standard tractor prop, if the shaft is facing aft take the standard tractor prop, keep it facing the same way as if it was on the front, put it on the motor, and reverse the polarity.....
and thats just how Dave's airboat is at the minute :-))
if you are still awake after that :}
can i please have some thunderbolts over Taylor park now! O0
seriously though... anyone who has had owt' ta do with aviation in an engineering sort of way (for the last 37years) can just look at a prop and read a lot of information about what it is fixed too!
db
The man said RUN. Props don't run..... motors do.....the rest of the explanation is fine  :}
LarryW
« Reply #28 on: February 07, 2011, 11:53:55 am »
HI ALL ,air boat ready for water , crew man having a bad hair day. ok2.....
now whaT to start next........looking at a trow mmi plan aboat 2ft long may suit a card build............LARRY
triumphjon
« Reply #29 on: February 07, 2011, 01:55:10 pm »
just a slight concern , your crew members hair looking a bit long , it wont get tangled in the prop will it ? jon
LarryW
« Reply #30 on: February 07, 2011, 02:01:21 pm »
hi JON , no mate , as it lacquered and wears a hair band :}    LARRY.
triumphjon
« Reply #31 on: February 07, 2011, 04:18:05 pm »
thats good then , it would be rather embarassing to have made an air boat only to be stopped mid lake cos the pilots hair was entangled around the prop !  <:(
LarryW
« Reply #32 on: February 10, 2011, 04:51:02 pm »
HI ALL  put the skimmer on the lake went well till itook on water through access hatch ....
 so decieded to build anther out of styreane only took 4 hrs  to build using salvaged bits from first one also no balsa or card to seal
     and made a better water tight hatch , will see this one go's  ok2     LARRY ...
stew49
« Reply #33 on: February 19, 2011, 09:35:44 pm »
Hi LarryW. like the build. ive tryed to find a plan but not found 1 yet. been tryin to get info off of your photos. %) photo 1 is good. could you put a photo of the bottom part of the plan :embarrassed:.
i know its a bit cheeky lol need to know how servo fits
 stewart :-))
john44
« Reply #34 on: February 19, 2011, 10:24:58 pm »
Well larry has got us all at it (making air boats I mean),
 I got photos and dimensions from the Alligator Tour site.
 You will have to work out your own way of building though.
 I used a sort of egg box type build for mine fitted with a 28/30/1270 brushless motor.
on a 8.4 NIMH battery.
Only tried it in the indoor test tank at the minute as I have yet to finish the cage framework.
stew49
« Reply #35 on: February 19, 2011, 10:30:37 pm »
Hey John44, a few of the guys at my local club have built them. thought i would have a go.
 what is the Alligator Tour site ?
you will have to put some pics up on here. :-))
john44
« Reply #36 on: February 19, 2011, 10:42:28 pm »
Hi Stew ,just type in alligator tour airboats and their website will come up on screen. They do 2 sizes a 30" IC model
and a smaller 18" electric version. Very easy to make.
stew49
« Reply #37 on: February 19, 2011, 10:50:28 pm »
Hey John, just had a look. nice models. good ideas. thanks. :-))
john44
« Reply #38 on: February 19, 2011, 10:54:56 pm »
Yes Stew, did you watch the video,s ?
For anyone else who would like to look at these airboats they are on www.aquacraftmodels.com
LarryW
« Reply #39 on: February 20, 2011, 11:20:23 am »
HJI STEW 49  if you are looking for plan  try long build or send me a pm   LARRY W .
The long Build
« Reply #40 on: February 20, 2011, 03:12:45 pm »
Skimmer 400 Series RDSMB 001..
Well went down to the pond today and saw one of the first completed builds by one of our members having a test run in the lake, this one is a bit heavier than it should be as not built from Balsa, I believe there is a second in developement for the races..
The Races we are having will be ruled that it must be no more than a 400 engine No Brushless and no Lipos, and the design must be true to the original. Originally I thought about 8 laps , Not so sure now, maybe 4 !!
We may move on to an open series type later.. :-))
Some pictures and Video  (Note to myself.. Do not talk while recording Doh..)
http://www.youtube.com/watch?v=4k44C2wtqBM
Larry R..
LarryW
« Reply #41 on: February 20, 2011, 03:28:32 pm »
HI Larry just watched video model looks good , fun ain't they :-)) but what motors are you using and prop size ?...
   there seems to a lOT  interest in this format , lets have some more fun , why should the springers have it all?
     keep on rocking ....LARRY   ok2
The long Build
« Reply #42 on: February 20, 2011, 03:40:51 pm »
Hi Larry
we are staying true to the original plan and using a 400 motor, the props we have are Gonther Pusher props at 5 inch No.302 125 x 110.
LarryW
« Reply #43 on: February 20, 2011, 03:45:26 pm »
HI LARRY who are your prop suppliers?       i use a 5x 6 ac prop but i reverse motor  ... LARRY...
The long Build
« Reply #44 on: February 20, 2011, 04:07:18 pm »
We got our initial supply from
http://www.rcmodelcentre.co.uk/index.php?_a=viewProd&productId=262
I know are local Steve Webb model shop also sells them where I aquired a spare..
LarryW
« Reply #45 on: February 20, 2011, 04:17:19 pm »
THANK YOU LARRY .... LARRY.. :-))
Roadrunner
« Reply #46 on: February 21, 2011, 11:14:39 am »
I would post a link to the product if the site was running.. but MMM do a air boat hull in vac formed styrene, there is talk of 'keeping to the plan' would this hull constitute keeping to the plan but with a pre formed hull?
@ around the £14 its not bad but not sure if its worth its value given its only 1.5mm thick  {:-{
destroyer42
« Reply #47 on: February 25, 2011, 06:36:57 pm »
Hi all,
I made one last year but a slightly modified version with pusher prop & brushless motor with twin air rudders. I found it worked like the real thing
Destroyer42
ray123
  • shuswap tugboat
« Reply #48 on: February 25, 2011, 08:14:49 pm »
looks well   colin   if the pond has been drained at 'southend' then this will work a treat :-))  regards ray
LarryW
« Reply #49 on: February 28, 2011, 03:13:34 pm »
 HI ALL , some pics of scimmer no 2 still trying to get a prop to get abit more go O0 LARRY....
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.169 seconds with 18 queries.
