Pages: 1 ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23]   Go Down
Author Topic: Mark's "Le Rochefort" Build 1/24 Scale  (Read 303471 times)
B.B
  • B.B
Re: Mark's "Le Rochefort" Build 1/24 Scale
« Reply #550 on: April 12, 2025, 12:26:23 am »
Hi Mark , I doubt the original vessels were built to the perfection you have built your model to , acred it to you, cheers.  :-)) .....
Brian  B
Mark T
« Reply #551 on: May 31, 2025, 05:03:25 pm »
Hi All
It's been a while since I posted and that is because I found an error on my build that occurred 3 1/2 years ago.  The error was that I had set the rear counter timbers at the wrong angle which to put right at this stage would have been incredibly difficult. So I thought the best thing to do was to just step away for a while and get a fresh outlook on the build.
I discovered this error when I fitted the stern timbers and stern windows.  The stern timbers went above the counter timbers and the windows were far too close to the rear quarter deck beam.  I did actually think about not finishing it but you know how it is - upwards and onwards!
So to get things back level I had to do some sketchy repairs starting with the rear quarter deck beam which now required lifting upwards.  Rather than do that I simply made it thicker than the plans.
Next I made the beams for the quarter deck - here's the process in pictures
I always enjoy cutting the dovetails its a very satisfying process
The beams were then set into the clamps at there correct heights using a height gauge and they were sense checked simply using a ruler
Next was to make the beam supports which sit under the beams
And finally the waterways that sit above the beams.  These parts had to be bespoke due to the error that I had made.
The waterways were then shaped to be level with the planksheer and the notches for the carlings were cut in.
So now that the quarter deck beams are complete I can remove them all and get on with some of the interior details.
I saw the pictures of Mayhem and it looked like a fantastic weekend - amazing!!
We are off to Crete next week for 2 weeks to celebrate my wife's 60th birthday so I'll be back on the build after that.
Thanks Mark
Footski
« Reply #552 on: May 31, 2025, 06:17:01 pm »
Mark, I seriously doubt that any ship came off the slipway exactly as the plans dictated.
Modifications and unplanned alterations were very frequent indeed.  Your model is superb. Only on criticism.......we have to wait too long for updates.. O0
JimG
« Reply #553 on: May 31, 2025, 09:40:50 pm »
Mark, a very good refit to adjust it to the correct proportions. You are basically replicating the historical shipwrights skill as they did not work to accurate plans but built from their experience. At the most there would have been a model, either full or half to show the lines.
Jim
Dundee Model Boat club
Mark T
« Reply #554 on: June 01, 2025, 09:13:29 am »
Hi Footski and Jim
Thanks for the comments  :-))   I'm definitely back on track and funnily enough just about everyone I have spoken to has said exactly what you both have!
Sorry about the slow build I just wish I had more time on my hands.  I've made a start on the interior quarters now so hopefully have an update soon.
Cheers Mark
SailorGreg
« Reply #555 on: June 03, 2025, 11:49:44 am »
Just caught up with your latest instalment.  I know honesty is the best policy - but you could have cracked on without telling us, and we would never have known!  Great fix, and as has been said before, every wooden ship had deviations from plan, repairs, refits and so on, so yours is just the same.  I am still in awe of the neatness of your work, such as the notches for the carlings.  Sharp tools, a steady hand and a good eye do the job - but yours seem sharper, steadier and better than anyone elses!
Greg
Mark T
« Reply #556 on: June 07, 2025, 05:42:26 pm »
Hi Greg - thanks but I must confess that I cut the notches for the carlings on my milling machine.  I find this way I get a uniform depth which makes fitting them tightly so much easier.   As the cutter is round I just have to square the corners up using a chisel.
DJW
« Reply #557 on: June 26, 2025, 10:32:25 am »
Hey Mark
The build gets ever more mind bending in it's detail, incredible detail.  I'd have reached for the epoxy before even contemplating those dovetail joints.
And as for the 3.5yr old glitch, have to agree with earlier comments, all these boats were basically hand built back in the day I'd reckon the plans were more of a guideline with parts shaped to fit what was actually present rather than in the plans.
Great work..!
David.
1/10th Aquarama Build - https://tinyurl.com/riva-aquarama
1/5th Aquarama Build - https://tinyurl.com/riva-aquarama2
Mark T
« Reply #558 on: June 27, 2025, 08:54:56 pm »
Hi David
I'm just back from holiday and thanks for your comments mate  :-))
Its funny when you step away for a while and then come back all of the worries I had before have just disappeared
Back to building tomorrow  ok2
Cheers Mark
JimG
« Reply #559 on: June 28, 2025, 12:39:35 pm »
When a ship did have actual plans drawn up they were not full scale. The shipwright then had to scale up the drawing onto the floor of the cutting room whee templates would be made before cutting wood. The videos on restoring Tally Ho shows this process. Even with our modern measuring methods they still had to fair in the frames before planking. Even a small error in measuring could give a large error in the full size wood part.Many of the existing ships draughts we use to build models from are not those a shipyard woulod have used but measured from the completed ship later in it's life, especially for captured ships.
Jim
Mark T
« Reply #560 on: June 28, 2025, 03:25:02 pm »
Hi Jim - that is spot on  :-))   When the shipwright was given the plans they had to be lofted to the full size part for the ship builders to use as a full size template.  The reason it was called "lofting" is because the loft of the workshop was the biggest flat area where this work was traditionally carried out.
Mark T
« Reply #561 on: June 29, 2025, 04:53:26 pm »
Hi Guys
Well after a lovely holiday I'm back at it - this time I'm making the wall with double doors that separates the main deck from the crews quarters.  It's a shiplap wall so firstly I made the shiplap planks and got them all glued together.
Next was the doors - I usually use a solid piece of wood and mill the features into it to make it look like a door.  I thought on this occasion I would try a new exercise and make them exactly as they would have been.  So each door has 5 pieces in the frame with 4 inserts to complete them.
The frame parts
Milling out the rebates for the 0.7mm thick inserts
Sorry I should have taken more photos but here are the assembled doors - the assembly was the hardest part
Next I milled out the door frame uprights and the wall base plates that the walls fit into along the lower deck.
All of the current parts assembled
After a bit of fettling the whole assembly fitted into the ship quite nicely
I did have one issue and that was the door frame uprights not allowing the whole assembly to sit flush with the beam.  This maybe because I read the drawings wrong but to overcome this I cut 2 rebates into the beam to accommodate the uprights.  This has actually made everything more stable and solid too.
Its still very much a work in progress but I'm getting there.
Thanks for all of the really nice comments and discussion too  :-))
Cheers Mark
Footski
« Reply #562 on: June 30, 2025, 07:02:17 am »
Such skillful dedication is an inspiration to us all Mark. Wonderful work as usual.
DBS88
« Reply #563 on: June 30, 2025, 04:08:52 pm »
Absolutely stunning work, your photos are are joy to see, congratulations on what you have achieved to date, its spectacular
Mark T
« Reply #564 on: August 03, 2025, 03:13:30 pm »
Footski and DBS88 thanks very much  :-)
I've got a little more done and this time it's the ships 2 beds.  One of for the Master of the ship and the other for the Master Gunner who was on board when Le Rochefort was loaded with her cargo of gunpowder.
I made the cupboard door and lower part of the bed recess in the same way that I made the cabin doors
The I made the cupboard walls and the base of the beds.  Finally I made the hinges and door handles to finish the parts off.
Fitting the parts was the hardest part trying to get a good a fit up against the hull as possible
So I just need to make the hatch surround, fit the beams and make the carlings and the quarterdeck will be finished  :-))
Cheers Mark
« Reply #565 on: August 03, 2025, 10:59:57 pm »
Hiya Mark, I just finished catching up with your build , from where you just got back from the holiday. Absolutely cracking job mate - love it!
Cheers,
« Reply #566 on: August 03, 2025, 11:39:42 pm »
Summer Break over Mark!  O0
Mark T
« Reply #567 on: August 04, 2025, 02:01:29 pm »
Hi Ray and Martin
Yep the holidays are over now until October so I’m back at it. Should have another update soon
Cheers Mark
Pages: 1 ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23]   Go Up
Page created in 0.244 seconds with 19 queries.
